In my 351 ive noticed my oil pressure fluctuates. some days its almost past the "R" in Normal, and then other days it will barely be touching the "O". It usually stays at where it is for the day so if its next to the R it stays there and wont go down to the O, and vice versa. I know the oil pressure gauge is like a dummy gauge so I'm sure its not actually fluctuating that much, but could there be a reason behind why it will go up and down like that? I use 6 quarts of 5W-30 synthetic blend motorcraft oil, as the owner manual says I should use. Could the cold weather be a factor too? I get anywhere from teens to low 40's where I live.
You won’t know what is actually happening until you put a mechanical gauge on it. I think you should be able to rent one from a parts store. I’m guessing you have a 90’s truck if it calls for synthetic blend oil
the owners manual actually calls for conventional, but it says that its ok to use synthetic if it meets the specs. Seeing as engine oil has improved alot in the past almost 30 years I just assume that any oil now meets and passes the specs so I just use synthetic blend.
I had a similar problem and i replaced the oil pressure sending unit.
I'm not sold that all gauges are 'dummy' gauges.
I agree but the pressure gauge definitely isnt that accurate. Really its just "good enough" so that you know if you lost oil pressure and can prevent engine damage. I had a 98 jeep cherokee and the gauge was very accurate. You could see it move fairly quickly when i went from idle to acceleration, and it even was numbered. I wish the gauge on my truck was like the jeep one.
I tend to agree but what are the odds of the oil pump failing? Most people like gauges, but they tend to only be looked at too late. I can tell you countless number of stories where people have overheated the engine to the point there was aluminum transfer on the cylinder walls. That is when they looked. No, I am not saying it was you. As far as I am concerned idiot likes and gauges work well together.
I put a larger fuel tank at the rear of my F250. The level gauge fluctuates way too much. I don't like it at all.
the owners manual actually calls for conventional, but it says that it’s ok to use synthetic if it meets the specs.
Which is why I said you must have a truck from the 90’s. There is no mention of synthetic oil in my ‘87 and ‘89 owner’s manuals.
That’s because only the oil pressure gauge is a dummy gauge.
Originally Posted by Jsouz50
I agree but the pressure gauge definitely isnt that accurate. Really it’s just "good enough" so that you know if you lost oil pressure and can prevent engine damage. I had a 98 jeep cherokee and the gauge was very accurate. You could see it move fairly quickly when i went from idle to acceleration, and it even was numbered. I wish the gauge on my truck was like the jeep one.
The Jeep probably had a real oil pressure gauge. I converted the one in my ‘89 to a real gauge but I don’t know if you can do that in the ‘92-96 trucks- something about the stepper motor being different.
