Switched 12 volt source?
Old Dec 30, 2025 | 03:40 PM
gstrom99's Avatar
gstrom99
'65 Flareside, with a swapped 302 and 4bbl. What's the best/easiest spot to get a switched 12 volt source? I need to run a switched 12v hot to the choke and (probably) eventually an electronic ignition dist.
Old Dec 30, 2025 | 04:05 PM
BobbyFord's Avatar
BobbyFord
Stator terminal of the alternator for the elec choke.
Old Dec 30, 2025 | 07:27 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
If you aren’t trying to stay 100% stock - Blue Sea, who make lots of marine electrical parts, makes at least one combination panel that has circuits from an unswitched as well as a switched sources. You’ll have to take care of the wiring for it. It also has a ground bus bar in addition to the switched and unswitched bars, and there are provisions for fuses for each circuit coming off the bus bars. The best place to locate that or any auxiliary panel is on the inner fender, as close as possible to your battery. Best practice is, in my opinion, a separate ground wire instead of relying on bonding things through the body. This is what is done on motorcycles.
Old Dec 31, 2025 | 07:46 AM
gstrom99's Avatar
gstrom99
Thanks. For the future electronic ignition, it looks like I should pull from the "C" terminal off the ign switch, before it turns into the dreaded PINK resistor wire.
It would be a different thread, but I haven't messed with points in a LONG time and no longer have my old Penske/Craftsman dwell meter.
Old Dec 31, 2025 | 08:59 AM
Thunderkiss1965's Avatar
Thunderkiss1965
If you are going to run switched ignition straight off the switch, before the resistor for ignition, I would use that same source to trip a relay for the choke, and power the choke straight from the batt side of solenoid.
Old Jan 1, 2026 | 11:48 AM
JimsRebel's Avatar
JimsRebel
This is the best method for the electric choke.
The choke doesn't start to pull OFF until after the engine starts.
Using the Key ON method, the choke will pull OFF if you leave the key ON for a while, before starting the engine. Sometimes the 12 volt power is run through an oil pressure switch, to keep this from happening.
Jim
Old Jan 1, 2026 | 12:24 PM
gstrom99's Avatar
gstrom99
What is the running voltage of the Stator terminal on the alternator? I haven't checked mine (yet), but read online that it is only 7 - 8 volts. Edelbrock instructs that the choke needs 12 volts, and specifically says "NOT TO COIL OR ALTERNATOR". At 8 volts, it won't fully open.
I think I'm still asking ya'll for a better "keyed 12v source"...
Old Jan 1, 2026 | 01:08 PM
Crop Duster's Avatar
Crop Duster
Just connect it to the center terminal on the ignition switch with an inline fuse. There aren't a lot of options with the switches in these trucks. The center terminal is the accessory terminal it is hot on run and acc. The red wire that the pink resistor wire is connected to is only hot on run, but you aren't supposed to connect the choke to the coil wire so that one is out.
Old Jan 1, 2026 | 01:24 PM
JimsRebel's Avatar
JimsRebel
The short answer is the alternator Stator output works fine. A lot of folks use it.
I did some bench testing to see the time difference, use 7 volts compared to 12 volts.
I found it took one minute longer to open the choke FULL open, when using 7 volts.
You should just test this on the truck, run the wire from the stator output to the electric choke and then start the engine see if the choke fully opens.
You shouldn't use the coil positive as a power source because it's downstream of the pink resistor wire. Additional loads on the resistor wire cause it to get to hot and this also lowers the coil positive voltage.
Regarding a 12 volt key ON source.
1) So you could run a wire from the key switch.
2) Some Carb install instructions recommend using the alternator Stator output to trigger a relay. This solves the problem of the choke starting to pull before the engine is actually running. The longer the time it takes to (crank) start the engine, the more the choke butterfly moves. The more it moves, the harder it is to start the engine.
It also keeps all the wiring in the engine compartment.
Personally I feel you are over thinking this. The simplest approach is usually better.
Jim
Old Jan 1, 2026 | 01:52 PM
BobbyFord's Avatar
BobbyFord
Edelbrock doesn’t build cars. Ford used the stator terminal for a power source for the electric choke for many years.
My 63 and 72 are both wired off of the stator terminal.
Old Jan 1, 2026 | 03:45 PM
gstrom99's Avatar
gstrom99
I agree on the "you're over thinking this". I do that alot. Yes, Edelbrock didn't build the truck, but they DID build put their name/decal on the carb. I've got some tinkering to do.
Thanks all.
Old Jan 2, 2026 | 04:56 AM
Crop Duster
Thanks all.
If Edelbrock's instructions say run a full 12V then hook it up that way. It is true Ford used the stator terminal to help the choke to pull off faster than it would with just a hot air choke stove. But at the same time, they used a choke stove and in some cases a temperature actuated vacuum canister to stage the choke. They never used the stator terminal as a stand-alone method to operate the choke.
A pure electric choke will never give you that just start it and drive off type of operation that the factory engineered systems did, but they work good enough to get the thing running.
Old Jan 2, 2026 | 08:35 AM
gstrom99's Avatar
gstrom99
From the wiring diagram I have, there appears to be a connector before the resistor (pink) part of the ignition feed wire coming off the switch. Is that a standard size male/female connector that I can disconnect and just run a new wire? I read a post here (2024) that Ford used proprietary size (.180" - per CropDuster - thanks) plugin connectors. Is there a source for these special sized ones? I'd rather just pull the Ford bullet connector (pink wire) and run a new wire, not splice in with a "Scotch connector" - I don't like those.
Old Jan 2, 2026 | 09:47 AM
Crop Duster
I believe NAPA has the correct connectors. They will most likely be behind the counter just ask the parts guy. If not, they are available online. The female bullet connector you mentioned is only used for the (pink)coil wire, but it is full power from the battery. If you use that you will need to add a wire to it because if you unplug the pink wire, you won't need a choke since the engine won't run no matter what. You might want to check the voltage drop on that wire with the engine running since there is no power on that wire when the engine is cranking.
Old Jan 2, 2026 | 10:00 AM
gstrom99's Avatar
gstrom99
Thanks. The plan is to run full switched 12v out and use that for both the electric choke and a Pertronix ignition. If I can get a good solid plugin bullet connection on that wire, that's what I'll use.
