Upgrading alternators
Old Dec 30, 2025 | 01:08 PM
1994F150351w's Avatar
1994F150351w
4wd Low
1980 F250 with the inline 6, and I want to upgrade my alternator from a 35A to a 70A. Is it as easy as swapping the alternators out? Or is there more involved? Do I have to mess with the starter solenoid? I’m going to be running dual batteries and an 85A isolator, too, if that helps. I’ve read somewhere that I need to get a bigger charge cable? I’m not sure. Any help is appreciated. TIA
Old Dec 30, 2025 | 01:16 PM
Max Capacity's Avatar
Max Capacity
Is this what your looking for https://www.ford-trucks.com/forums/1...tallation.html
Old Dec 30, 2025 | 02:45 PM
JimsRebel's Avatar
JimsRebel
Do you have an AMP meter?
Do you want to keep it or switch to a volt meter?
I believe you can buy a new 3G alternator for about the same as a rebuild 1G.
https://www.ford-trucks.com/forums/1...ator-swap.html
Jim
Old Dec 30, 2025 | 03:46 PM
Denzil B's Avatar
Denzil B
The 70A is still the 1g alt so it should not require much of a change up. Many recommend the 3g upgrade. I (just completed a3g 95A myself) think it is worth the extra effort but your needs may differ from mine. You can find info on that at garysgaragemahal.com look it up under bullnose upgrades.
Old Dec 30, 2025 | 05:38 PM
FuzzFace2's Avatar
FuzzFace2
I would have to ask why the dual batteries and the extra AMP ALT?
The only difference I know of between the 35A and the 70A is the way the wires get hooked up.
One has studs the wires go on and the other a plug on the top.
Because I used the ALT (stud type) from my truck and the harness (plug type) I made jumper wires to make mine work.
Dave ----
Andy_W
6.4L Power Stroke Diesel
Nov 17, 2014 08:58 PM
twom7
May 6, 2013 06:07 PM
Ashton_1012
Feb 22, 2012 10:09 PM
MOOK929RR
Apr 21, 2006 07:48 PM
cterrysgd
Mar 2, 2005 07:58 PM
