High Idle electrical gremlin.
Old Jan 10, 2026 | 06:02 PM
  #31
krooser's Avatar
krooser
Originally Posted by 90project5.0
If you don’t have access to a smoke machine, you can use something as thin as a coke
can, cut a piece, and make a temp “block off plate between the EGR and the intake. If it doesn’t do it again, found that problem! As for the tps, did you have the battery disconnected while redoing the computer?
That replacement cap area looks suspect. I would ohm it to make sure it’s good. Inspect the entire board!
An ohm meter won't test anything...you need a capacitance tester to show the caps microfared's. The ESR is a factor when choosing a high dollar cap but not in a burned up cap.
I just bought one on Amazon for $18.... I repair guitar amps on occasion.
Old Jan 10, 2026 | 06:18 PM
  #32
90project5.0's Avatar
90project5.0
Ohms test can show you if a trace is broken. The guy that rebuilt mine showed me all the different ones that were broken.
If for some reason solder wasn’t making the connection, it would show if you tested before and after the solders.
Old Jan 12, 2026 | 08:30 AM
  #33
Dentside Lover's Avatar
Dentside Lover
Glad to hear you did it man. Have a good one. Can't wait for that beer!
rvborgh1
1983 - 2012 Ranger & B-Series
Aug 10, 2019 06:25 PM
Anthonynoble
Aug 24, 2016 04:13 PM
quisp-n-quake
Sep 25, 2007 09:24 PM
spiritwild
Bronco II
Mar 11, 2007 05:30 AM
broncobillybob
1978 - 1996 Big Bronco
Jan 27, 2004 08:19 PM
