Hi all, I am looking at picking up a 1958 F-100. It is in good shape, I will use it on the farm in the summer to pick up lumber, grain an other items that I don't need to use my Superduty F-350. My Superduty has a sprayed in liner and a rubber mat to help keep payload from sliding around. That being said, should I do something to protect the 58 bed. I do not think I should use spray in liner, but what should I do, if anything, Thanks for your assistance
Wolfcoln
Thanks, I left out that bit of necessary information. It is a pretty good looking floor and I know I would put a full size rubber mat in it to help protect the floor, it is the rest of it.
Originally Posted by tjc transport
is the bed steel floor or wood?
I'd rust repair it, then paint it, then use a rubber mat if you want. A rubber mat will trap moisture under it longer than if the bed were just out in the open.
