1976 highboy
Old Dec 25, 2025 | 09:56 PM
basscat52's Avatar
basscat52
7th Gear
1976 highboy
Hello.so I bought a 1976 ford f250 4x4 highboy with np435 trans np205 2 speed transfer case dana 60 rear dana 44HD. Front axle big hubs. 360 cider. My question is on the rear leaf springs which are 2 1/4" i have the auxiliary springs but no spacer plate.can someone help me out with numbers or were to purchase spacers at thanks in advance.ed
Old Dec 26, 2025 | 12:31 PM
440 sixpack's Avatar
440 sixpack
Where does the spacer you want go?
Old Dec 26, 2025 | 02:22 PM
basscat52's Avatar
basscat52
7th Gear
Between lower 9 leaf springs and auxiliary leaf.it has to be 2 1/4"
Old Dec 26, 2025 | 02:29 PM
440 sixpack
That doesn't seem right. I think I have the same pickup as you, a '76 high boy with the 7700 GVW and I know it's unaltered. the spacer between the top spring and the overload is 1" .
I doubt they're reproduced, but it should be easy to find used ones or just fab a pair of them.
Old Dec 27, 2025 | 07:13 AM
HertzHound's Avatar
HertzHound
I’m guessing he’s talking about the width, and he can only find the 3” wide ones?
Old Dec 27, 2025 | 07:24 AM
Mark8man's Avatar
Mark8man
Approximate dimension. 5" long x 2 (or 2-1/16" max) x 1" thick as 440 stated. Shouldn't be too hard to find originals from folks parts trucks as its not a sought after part. Simple to make yourself or have metal fab shop make one. Probably requires center hole for alignment and retention.
Old Dec 27, 2025 | 08:17 AM
tbear853's Avatar
tbear853
Make two of them.
Old Dec 27, 2025 | 09:56 AM
440 sixpack
I've never seen an F250 with 2 1/4" wide springs. must be the lightest GVW.
The spacer would be easy to make.
Old Dec 27, 2025 | 12:34 PM
basscat52's Avatar
basscat52
7th Gear
i believe the rear springs at 21/4" is common for a highboy 3" on others. i had to check myself. fronts are 3"
Old Dec 27, 2025 | 12:38 PM
basscat52's Avatar
basscat52
7th Gear
thats it thanks for the come back
Farrell79Ford
Sep 6, 2011 08:25 AM
dyingtolive
Offroad & 4x4
Mar 28, 2011 12:43 PM
slayerman54
Large Truck
13
Jun 18, 2010 09:22 PM
fordguy_460
15
Nov 29, 2008 04:02 PM
eclectix
Offroad & 4x4
Mar 20, 2006 02:59 PM
