Tachometer stopped, tranny doesnt shift
Old Dec 8, 2003 | 11:21 PM
Baja Aha's Avatar
Baja Aha
Question Tachometer stopped, tranny doesnt shift
1993 Ford F-350 Diesel (not turbo) CrewCab 4x4
Hit a bump and my tach went dead. Furthermore, overdrive is off and can't be engaged, worse if I start out in drive it feels like the truck starts in high gear so I have to manually shift in to 1st or 2nd. No difference between 1st or 2nd either.
Bottom line: I think I've got an electronic tranny control problem, but don't have a repair manual - wire harness / connector going into top of gear selector is seated - any suggestions?
Thanks in advance
Old Dec 11, 2003 | 10:01 PM
Baja Aha's Avatar
Baja Aha
Smile Found the answer
Found the answer:
The tranny was operating in failsafe (2speed) due to a blown fuse feeding power to the 'computer'. The fuse was not under the dash, but rather in the power distribution center under the hood.
The diagnosis was assisted by the fact that the computer would not give out any status codes - indicating that it was either dead or not fed.
Looking back on my trip to Baja, there was evidence of how this happened.
1) road had a stiff drop off and this was the 'bump' that caused the tach and tranny to go dead.
2) later in the journey at night when chasing after a race truck in the baja1000 I encountered a strange phenomena - the lights would go very bright when the road was a certain bumpiness.
This was later found to be due to the ground terminal of the battery having come loose. My guess is that it was loose during the day and the bump leaving the road caused a surge which blew the fuse to the 'computer'
All is well now with the new fuse.
Old Dec 11, 2003 | 11:33 PM
dieselzen's Avatar
dieselzen
Congrats on the fix, Baja Aha,
Wish I hadn't missed your original post. You did a good job of tracking it down.
If you want, I could send you some diagnostic stuff for the E4OD in case it gives you fits again. Has a newly re-vamped TPS/FIPL test and adjustment procedure thanks to member, RxF.
You have your "receive email" function turned off in your "profile" so I can't send you an email and you can't email me as you haven't posted enough.
The board administrators could help you get the email enabled. R.A.
Old Dec 12, 2003 | 10:30 PM
Baja Aha's Avatar
Baja Aha
I've updated my settings so that my email is not private - it would be great to get the info on the tranny.
Your guidance on another thread (something about FIPL out of adjust actually gave me some hints).
Old Dec 13, 2003 | 06:59 AM
kidoo's Avatar
kidoo
Great you found the problem. I have that problem sometimes but it is intermittent. I changed the RPM sensor on the infector pump but it still did the same thing one time, Now it is ok.
Old Dec 15, 2003 | 08:42 AM
Baja Aha's Avatar
Baja Aha
Thanks for the tranny diag file
Thanks Dieselzen for the diag file - much appreciated.
Old Feb 11, 2004 | 04:10 PM
Garlicbreath's Avatar
Garlicbreath
to Dieselzen, I just baught a 93 F250 7.3L NA and and am having some issues with my tranny too, would be so kind as to email me those helpful diag. too?
Old Feb 12, 2004 | 09:46 AM
dieselzen's Avatar
dieselzen
Garlicbreath,
I sent you a private FTE email yesterday regarding how you can get the zip file from me. If you've deleted it by mistake, please let me know and I will re-send the message and instructions. R.A.
WB4IUY
Escape & Escape Hybrid
Oct 9, 2014 06:00 AM
dunecj2a
Jan 3, 2013 06:09 PM
zach_barrow
Feb 4, 2008 09:10 PM
lrac_m
Sep 22, 2006 08:14 AM
Andrew Schaffernoth
Aug 12, 2002 09:17 PM
