Carb Question
Old Dec 16, 2025 | 12:59 AM
saauvenshine's Avatar
saauvenshine
Carb Question
Have a Holley 94 carb on my 54 truck 239 ohv that I rebuilt. Truck starts but the fuel and air mixtures screws are not working. I can run them all the way in, and truck still runs when it should die. I know idle should decrease as they are turned in but it doesn't have any effect. Any thoughts? Have tried removing screw and blowing air in holes but no change.
Old Dec 16, 2025 | 06:34 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
It could mean the idle circuit is being bypassed. Throttle plate not closed? Idle screw not adjusted correctly? Power valve circuit engaged/leaking?
Old Dec 16, 2025 | 08:08 AM
Truckfarm's Avatar
Truckfarm
Vacuum leaks?
Really check for vacuum leaks also. Lines and carb base gaskets, etc.
Old Dec 16, 2025 | 10:08 AM
Jeeptrix's Avatar
Jeeptrix
I had the very same issue. When I reassembled the carb I inadvertently placed the float tab on the wrong side of the spring. Other than running a little rich the truck ran fine. I knew that if I couldn't lean it until it stalled there was something wrong. Easy fix.
PaulzF150
19
Aug 28, 2007 02:45 AM
72tank
Jun 21, 2006 11:59 AM
redneck250
Apr 17, 2006 01:13 AM
old number 12
May 28, 2005 06:30 PM
lee
Sep 26, 2004 10:49 AM
