2015 f150
Old Dec 15, 2025 | 09:24 AM
Ed Jarvis's Avatar
Ed Jarvis
7th Gear
2015 f150
What is required to put a heated rear window in my f150.
Old Dec 15, 2025 | 10:39 AM
GlueGuy's Avatar
GlueGuy
It would be helpful to know which rear window you have. Can you upload a picture, and maybe give us a clue which model/trim you have?
Old Dec 15, 2025 | 12:50 PM
JKBrad's Avatar
JKBrad
The way the rear glass is installed in these trucks will require you to go to an automotive glass shop to get it done. They can order the heated rear glass.
Old Dec 15, 2025 | 12:56 PM
Ed Jarvis's Avatar
Ed Jarvis
7th Gear
I have a xl model with a solid rear window.2015 model crew cab
Old Dec 15, 2025 | 01:39 PM
JKBrad's Avatar
JKBrad
I'm not sure if the wiring is included in the trucks harness, it may be. You would need the connection in the back for the wire to the rear glass, and a connection behind the dash panel to add a switch to turn it on.
Old Dec 15, 2025 | 04:32 PM
SpencerPJ's Avatar
SpencerPJ
Back in the day, they had 'aftermarket tape on versions'. That or a heated blower style is what I would look into.
danso**
2015 - 2020 F150
Apr 9, 2022 03:21 PM
makthenif
1997 - 2003 F150
May 18, 2006 04:41 PM
beartracks
Sep 21, 2001 07:22 PM
froman23
Sep 10, 2001 09:14 PM
