dash brightness annoyances
Old Nov 23, 2025 | 05:13 PM
muhford's Avatar
muhford
Has anyone had any luck dialing in their dash brightness?
When I get in my truck at night the dash is blinding and I have to always dim it. Then if I decide to turn off my headlights in a parking lot or whatever the dash turns back to daytime mode and blinds me. Yes, I can manually choose night mode but then it's always in night mode.
Dash lights on older vehicles were much better. You just had one **** for everything. Now I have to mess with ***** buttons settings yada yada.
Old Nov 23, 2025 | 06:38 PM
Bent6's Avatar
Bent6
Have you used the buttons to the right of the light ****? They can be dimmed. I’ve never had a concern after adjusting mine.
Old Nov 24, 2025 | 10:28 AM
GlueGuy's Avatar
GlueGuy
It might be the daylight sensor on the front of the dash (under the rearview mirror close to the windshield).
If you cover it with tape or something it will sense that it's dark, and make the dash dimmer. This sounds like your symptom, and if you cover it you will see that nothing changes. Not sure how to test it though.
Old Nov 25, 2025 | 04:53 PM
2017coyote's Avatar
2017coyote
2017 here and no issues once set to where I want it.
Old Nov 25, 2025 | 05:30 PM
muhford's Avatar
muhford
Yes that is what I'm saying. I have to mess with those buttons constantly because my truck is a smart truck and it knows what's best for my eyes.
Old Dec 4, 2025 | 10:56 PM
blackestate's Avatar
blackestate
Similar issue with mine. I have to adjust every time I get in at night I have not found any solution. My dash seems ok.it is the radio that blinds me
Old Dec 5, 2025 | 06:31 PM
muhford's Avatar
muhford
I found a bandaid solution. Set the radio to night mode, then manually adjust the brightness all the way down.
Old Dec 12, 2025 | 02:26 PM
danskool's Avatar
danskool
Go Bills !
I thought it was just me, I am always fooling with the dash brightness buttons with my 17 5.0, I have never fooled with such things in any other vehicle i owned.
Old Dec 12, 2025 | 04:36 PM
2017coyote's Avatar
2017coyote
my 17 5.0 stays where I set it. I do only set it in park while running and I always push OK.
Old Dec 16, 2025 | 12:33 PM
blackestate
I also have noticed if it is completely dark, or it comes on when driving, then it works like it should. But if there is any street light the dash works correctly but the radio doesn't.
Quigoline
Nov 18, 2024 11:27 PM
jed1894
Jan 13, 2016 08:29 PM
spoolen&smoken
6.4L Power Stroke Diesel
Apr 12, 2013 11:08 AM
