Sponsored by: Real Truck
P2285 Control Pressure Sensor Circuit Low
Old Dec 15, 2025 | 08:57 AM
moodperson's Avatar
moodperson
2004 F250 6.0L
I sometimes get this code (P2285). I clear it out with my Torque Pro app and it only comes back intermittently. The ICP pressure is about 750 at idle and IPR is 29%. FICM voltage is 48.5. HPOP is 1110.
This morning it was very cold (15 degrees F) and it started right up
Does anyone have advice about what might be happening? Also, I run full synthetic.
Old Dec 16, 2025 | 07:46 AM
Baylinerchuck's Avatar
Baylinerchuck
You would do better to head over to the 6.0 section of the forum and post your question there. If the issue is intermittent, there could be a wiring issue in the harness or a true high pressure oil leak if the engine stalls.
Derickmelvin
Jun 22, 2022 06:33 AM
martin14sk
Aug 2, 2017 08:42 PM
quality1construction
Feb 18, 2015 06:47 AM
Hootch
Mar 4, 2013 02:28 PM
valiant500hp
17
Nov 16, 2011 10:50 AM
