All of a sudden I find my truck 2001 F150 5.4 triton flair side with no instrament pannel lights but all the idiot lights are working and I have no tail lights but brake lights and blinkers work so what the hell is wrong and before someone suggests the dimmer switch it has never worked so it can't be the problem .plz help me
Passenger compartment fuse panel
The fuse panel is located below and to the left of the steering wheel by
the brake pedal. Remove the panel cover to access the fuses.
To remove a fuse use the fuse puller tool provided on the fuse panel cover.
18 5A Instrument Illumination (Dimmer Switch
Power)
19 — Not Used
Both the instrument panel and the parking lights go through the light/dimmer switch.
Difficult to diagnose an electrical circuit problem when there is a known faulty component in the circuit. Seems like the correct course of action is to fix the known problem then search for the unknown problem(s).
