Sponsored by: Real Truck
2015 PSD Faults
Old Dec 12, 2025 | 08:16 AM
LariatRick's Avatar
LariatRick
2015 PSD Faults
I'm getting 3 faults:
Wrench symbol
Service Advancetrac
Check Brake system
The transmission goes into limp mode and downshifts without shifting back up unless I stop and put in park.
Someone said its a bad wheel bearing, so dont drive it. According to the manual, the wrench symbol means a drivetrain or AWD fault has been detected. Its got 4wd not AWD. Is a wheel bearing part of the drivetrain?
It just had a bad brake switch replaced.
Any idea whats the problem? Your feedback is greatly appreciated.
Thanks
Rick
Old Dec 13, 2025 | 01:42 PM
Eman85's Avatar
Eman85
Problem is you need to scan the systems and see what trouble codes the lights were turned on for. Guessing and replacing parts with no diagnosis is a losing game.
Bad brake switch? Why was it replaced? Did it fix the initial problem?
HUNTER10
Dec 15, 2009 11:41 AM
jeff2761
Jan 14, 2007 10:41 AM
zjmt12
Jul 14, 2005 01:15 PM
onestrangebroncoII
Offroad & 4x4
Oct 7, 2004 05:24 AM
