Odd light behavior
Old Dec 12, 2025 | 07:10 AM
Poncho450's Avatar
Poncho450
Odd light behavior
I made a FORScan change a long time ago so that my fog lights are on with DRL. They used to be on whenever DRLs were on. It was nice because I have yellow Lamin-x film on the fogs and it made for a nice contrast with the white of the C rings on the headlights for better visibility.
I see that now the fogs are not operating with the DRL while the steering is pointed straight. However, when I turn the steering wheel in either direction, the corresponding fog light for that side only comes on. Could this be some kind of BCM change that was made when the truck was in for service? Is it a stock module configuration these days?
The truck was in several times for a non functioning traction control system as well as a telematics control module replacement. That was quite some time ago, maybe I'm just noticing it recently when I see the reflection of the lights as I pull into my driveway.
I just glanced over the FORScan spreadsheet and don't see a specific position for this anymore.
Old Dec 12, 2025 | 04:19 PM
kudie's Avatar
kudie
Veteran: Marine Corps
Cornering lights setting on dash?
Old Dec 13, 2025 | 05:28 AM
Poncho450's Avatar
Poncho450
Good suggestion. I'll see if I have that setting and check it out.
Old Dec 13, 2025 | 09:49 AM
Poncho450's Avatar
Poncho450
No luck. Cornering is not shown under the lighting settings. Or anyplace else on this truck. It was worth a shot.
According to DuckDuckGo AI it's a FORScan thing. Nothing about the function turns up on this site's spreadsheet but it may be one of those things that appears in the "plain English" side of FORScan.
Old Dec 13, 2025 | 12:10 PM
kudie's Avatar
kudie
If foglights are on they shouldn’t do that
Old Dec 13, 2025 | 12:15 PM
Poncho450's Avatar
Poncho450
Problem solved with FORScan non As Built side. As it turned out, the fog light switch had somehow been deactivated too. No idea how that happened.
Looks like I unintentionally changed the front turn outage while I was in there. That has since been returned.
Old Dec 13, 2025 | 04:00 PM
twobelugas's Avatar
twobelugas
Hmm I might have to do this too and just turn the danged things off for turning, I am not too impressed by the "cornering" lights since fog lights are by design set to a very low cut off. When I go around corner I want a more vertically spread out coverage to see humans walking in the dark and whatnot. Those who had older Lincoln and Mercury vehicles will know what I mean.
Old Dec 13, 2025 | 04:56 PM
Poncho450's Avatar
Poncho450
I do know what you mean. I had a 1998 Town Car within the last year.
Old Dec 13, 2025 | 05:03 PM
dammitman's Avatar
dammitman
I gotta learn about forescan,,,,
Old Dec 13, 2025 | 08:48 PM
Poncho450's Avatar
Poncho450
My problem is that I only use it very infrequently. Biggest problem I have is getting the license key and hardware ID squared away. I only use the 2 month free license so I have to sort that stuff out every time I begin again. I’ve always used Mac stuff so I have poke around feel my way through Windows.
Thanks kudie for sending me down the path of cornering lights. It eventually got me a solution.
4Seams
Apr 22, 2025 01:53 AM
Phillbo
Mar 29, 2025 12:43 PM
Robret.F150
2015 - 2020 F150
Jul 14, 2024 12:06 AM
mark_k
Electrical Systems/Wiring
Oct 10, 2021 05:40 PM
sxrfun
Nov 20, 2017 10:12 PM
