Sponsored by: Real Truck
Both crew cab doors broken
Old Dec 11, 2025 | 08:38 PM
TretpFlyr's Avatar
TretpFlyr
Well, it had to happen. For the past five years, my drivers rear crewcab door would not open. I did everything from rhe passenger side door but now it is broken and latch inop. Got a big problem, any advice appreciated.
Old Dec 12, 2025 | 12:39 AM
INFRNL's Avatar
INFRNL
I'm guessing they wont open from outside or inside? I was going to say find someone with a slim jim or similar tools, but that might not work depending on where the actual issue it. Probably going to have to pull the rear seat somehow to get access to remove the door panels...unless the door panels can be removed without the seat in place.
no actual experience but that's what my brain is currently telling me.
Old Dec 12, 2025 | 07:34 AM
99powerstrokedF250's Avatar
99powerstrokedF250
<smartalec response> Go back in time 5 years and repair the driver's side latch.
<serious response> You'll need to remove the inner door panel to access the latch mechanism and try to get it to release, then replace broken components. This will likely require removing the rear seat...through the front door. Maybe it won't but it might, I don't recall if there is enough room to get the inner door panel off with the door shut, as I never tried. Once you get the door open things will be a lot easier to work on, so focus on getting the latch to release.
Old Dec 12, 2025 | 11:14 AM
TretpFlyr's Avatar
TretpFlyr
I will probably pull the rt passenger seat, then I will be able to get to the rear panel.
PJWhelan
Dec 5, 2023 11:05 AM
crazymut
16
Oct 14, 2023 07:59 PM
Blclark
Mar 8, 2022 05:01 PM
cabloom300
Apr 10, 2017 11:51 AM
ckearns
Dec 24, 2003 08:23 AM
