I have some questions regarding an air pump/smog pump delete for my 97 f250 351w. Hopefully I can be guided in the right direction.
1: Are there any detailed videos on youtube showing how to do this? I've found a few that are close but don't show everything .
2: Which sensors will need to be bypassed and tricked into thinking the pump is working? And do i need special aftermarket connectors, or resistors? I've heard that both work.
3: I've heard that I can modify the computer to completely remove the emissions system from it, thus being able to remove emissions equipment and not having to trick the computer into thinking its working. Is this true? If so, how can i do it?
4: Will having OBD1 make a difference when doing the delete? Because I have OBD1
any other tips i should know to do this delete would help out alot.
It's not that difficult just remove everything attached to the air pump. Follow the plumbing and mark everything with chalk or paint before you start ripping it apart.
None.
The computer barely knows it exists. just keep the TAB snd TAD solenoids electrically connected.
None.
3: I've heard that I can modify the computer to completely remove the emissions system from it, [/QUOTE]The computer barely knows it exists. just keep the TAB snd TAD solenoids electrically connected.
4: Will having OBD1 make a difference when doing the delete? Because I have OBD1 [/QUOTE] No.[/QUOTE]
I may have written my 2nd question poorly. What i mean is do i need to plug the sensor into a "dummy plug" that will trick it into thinking its working. I've seen before that you can use resistors, but I dont know what resistor (if i can use it) to use and what things need them after removing the air pump
[/QUOTE]
I may have written my 2nd question poorly. What i mean is do i need to plug the sensor into a "dummy plug" that will trick it into thinking its working. I've seen before that you can use resistors, but I dont know what resistor (if i can use it) to use and what things need them after removing the air pump[/QUOTE]
you don’t need any dummy plugs or resistors. Just leave the TAB and TAD solenoids electrically connected. People use resistors when those solenoids are unnecessary removed. I recommend you don’t remove them.
you don’t need any dummy plugs or resistors. Just leave the TAB and TAD solenoids electrically connected. People use resistors when those solenoids are unnecessary removed. I recommend you don’t remove them. [/QUOTE]
So removing the air pump wont cause problems with the TAB and TAD? It wont make a check engine light go off?
[/QUOTE]So removing the air pump wont cause problems with the TAB and TAD? It wont make a check engine light go off?[/QUOTE]
it will not cause a check engine light to come on I’ve ran mine this way ever since my air pump locked up and I removed it along with the rest of that system because I didn’t want to pay for the replacement parts.
it will not cause a check engine light to come on I’ve ran mine this way ever since my air pump locked up and I removed it along with the rest of that system because I didn’t want to pay for the replacement parts.[/QUOTE]
Ah ok, i see. Its strange how the sensors wont set off a CEL when emissions equipment is removed. Kinda defeats the purpose of it 🤣
I've got a '96 F250 w/ 351 and removed the air pump and everything that went with it including the tab and tad and the truck ran better. I removed all the canisters and vacuum lines also. The only problem I had was I removed the vacuum line that went to the MAP sensor and forgot to replace it. Once we got that straight everything was fine. The hardest part was getting one of the air pump bracket bolts loose but it just took time being easy with it. The nuts that connect the air pipe to the back of the exhuast manifolds came off fairly easy after heating them with map gas. I do have a CEL but I think it's because I removed the EGR which I may put back on. They claim 75ohm resistors in the tab and tad connectors will fool the computer so I put them in but don't know if it did anything. I also went with a shorter belt instead of the air pump dummy pulley and it works fine. I had a pile of parts after it was all said and done. The YouTube video I found most helpful was one with a Bronco but it still didn't show allot. Just get in there and and take off anything emissions related.
I forgot to add on my truck the only thing I had to buy was a shorter belt. The air pipe did not connect to the heads it connected to each exhuast manifold. I cut the pipe welded holes shut and reinstalled. I did buy the dongle for the egr but I doubt it did anything and I'd leave the egr next time.
