DEF level
Old Dec 8, 2025 | 07:36 AM
wmsnyder's Avatar
wmsnyder
DEF level
My 26 F350 was showing 55% DEF on the gauge so I added about a gallon. Then noticed it was dripping out underneath the bed, even though the gauge is only showing 66%. I am assuming the gauge is incorrect?
Old Dec 8, 2025 | 08:17 AM
1olddogtwo's Avatar
1olddogtwo
It takes a few minutes for it to recognize, it does not work like a fuel gauge.
Old Dec 8, 2025 | 09:13 AM
chadstickpoindexter's Avatar
chadstickpoindexter
The 22’s have a 7.5 gallon tank. Not sure about the 26’s, although I doubt it would be smaller. If it is also a 7.5 gallon tank and you were at 55% you should have been able to put 3 gallons in no problem. If you saw something underneath leaking it wasn’t from overfilling. Keep an eye on it and if you see it leaking again take it back in. Or, crawl underneath and check. If it’s as simple as tightening something up it’s way better to just tighten it than go through the hassle of letting the dealership handle it…
Old Dec 8, 2025 | 09:19 AM
wmsnyder's Avatar
wmsnyder
I am taking it in for something else, so I will have them check it out.
Old Dec 9, 2025 | 05:51 PM
powerboatr's Avatar
powerboatr
and def dried up on the concrete leaves a very telling mark of crystal looking stuff
Norfra
6.7L Power Stroke Diesel
Mar 6, 2016 05:44 PM
DieselRunner
Jun 6, 2007 01:24 AM
airwick51
Apr 29, 2004 11:47 PM
