TPS readings strang
Old Dec 7, 2025 | 06:14 PM
Jack the Third's Avatar
Jack the Third
6th Gear
TPS readings strang
There are a ton of great TPS threads on here and I hope someone could help with some strange readings I got through testing.
1994, f150, 302, E4OD
KOEO codes: 121 124
symptoms: shakey idle, wont shift out of first, will go to second if i put there on the shifter.
history: this thing has been pretty dang reliable, but i got a new car and it sat for a year. when it was parked it ran pretty well, no CEL, no major issues
well now i gotta get it running.
I took some readings from the TPS and this is what i got:
TPS readings:
key on engine off, warm
Red to batt neg: 5V
Green to batt pos: 4.5V
Black to batt neg:no reading
When unplugged the truck side connector shows
Red to batt neg: 5V
Green to batt pos: (battery voltage)
Before i tear of the throttle body, can anyone confirm this is a bad sensor and not something else?
Any other tests i should run before going replacement route?
Recommended brand for replacement?
Old Dec 7, 2025 | 07:37 PM
Junktownbill99's Avatar
Junktownbill99
To test the TPS, you need to probe the green wire (pos) and the black wire (neg) with a voltmeter. It should be .45-.9v at idle and 4.5-5v at WOT. It should transition smoothly as you move the throttle. (KOEO)
Black wire to orange wire should be 5v reference.
Old Dec 8, 2025 | 08:19 AM
Jack the Third
6th Gear
When I do that I get no reading.
Old Dec 8, 2025 | 09:11 AM
My4Fordtrucks's Avatar
My4Fordtrucks
You do have the sensor plugged in and back probing the wires, correct?
Old Dec 8, 2025 | 09:30 AM
Dave 78 F250 460 2WD's Avatar
watch this video I posted.
Old Dec 8, 2025 | 10:12 AM
wwhite's Avatar
wwhite
Originally Posted by Dave 78 F250 460 2WD
That is 100% incorrect way to adjust a GAS engines TPS.
Your video is with a DIESEL, not the same.
Old Dec 8, 2025 | 11:13 AM
I was unaware that there would be a difference. Thks.
Old Dec 8, 2025 | 12:06 PM
Junktownbill99
Old Dec 8, 2025 | 12:55 PM
Jack the Third
6th Gear
Yes.
Old Dec 8, 2025 | 01:06 PM
My4Fordtrucks
Yes.
Well then how did you get 5V and 4.5V before and now have 0V?
Old Dec 8, 2025 | 02:06 PM
AuroraGirl's Avatar
AuroraGirl
key is off or battery is run down
the tps has to be installed the right way to grab the lever on throttle
Old Dec 8, 2025 | 04:19 PM
Jack the Third
6th Gear
Here are the readings I got today
Key On Engine Off
TPS Connected, Probe inserted into back of the connector
TP SIG (black) to SIG RTN (green): 0V
SIG RTN (green) to SIG RF (red): 5V
TPS Disconnected
TPS side:
TP SIG (black) to SIG RTN (green): 60K OHMS upon rotating throttle variable changes but all in the XXK OHMS (i think the resistor inside the tps is blown)
Truck side
SIG RTN (green) to Batt Pos: 12V
SIG RF (red) to Batt Neg: 5V
Let me know what your thoughts are, I am leaning to resistor in the TPS being bad.
Old Dec 8, 2025 | 04:23 PM
Jack the Third
6th Gear
The voltage reading on the TP SIG wire (black) has always been 0V. KOEO
Old Dec 8, 2025 | 04:27 PM
wwhite's Avatar
wwhite
Old Dec 8, 2025 | 04:37 PM
Jack the Third
6th Gear
Sorry, i edited my above post. It was Black wire to Batt Pos (truck side connector, TPS unplugged, KOEO) gave me 12V which is believe is the correct reading
