I’ve got this strange engine noise from a 4.6 2V that has been going on for years. Only happens at about 1,200rpm, only under load. Seems to be coming from the drivers side bank. Sort of sounds like scratching or scrapping. Never happens higher or lower, doesn’t happen in nueutral.
Thanks for the response. I thought exhaust heat shield, but it sounds higher up in the engine, and coming from the left. I'm 99% sure it's not coming from the transmission.
I was wondering about the exhaust studs. I don't have a stethoscope, but I'm going to be working on my van getting the top re-sealed with a neighbor the next few days, and he might have one.
In lieu of a stethoscope, put one end of a long stiff rod (e.g., metal or hardwood) on the item in question and the other end against - not in! - your ear. Don't do that around moving parts!
