e4od adapter for t case
Old Dec 2, 2025 | 03:30 PM
Tillylamp's Avatar
Tillylamp
hi all, I've been reading about these adapters that connects to the rear end of the 2wd transmission that then you can use the t case on it, what`s the chances of finding one? are they still about? or are they a thing of the past? what's your thoughts.....
Old Dec 2, 2025 | 04:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Following. I've never heard of this.
Old Dec 3, 2025 | 06:52 AM
Olds64's Avatar
Olds64
Wow!
If Mark hasn't heard of it then they probably don't exist. Isn't the 2WD vs 4WD coupler/output shaft the last part to be removed from an E4OD during a rebuild?
I know you can get transmission adapters for older automatics. Here's a supplier that's well known on the Oldsmobile forum I frequent. They provide an adapter to get rid of the antiquated Slim Jim Rotohydramatic transmission (the second worst automatic transmission in the world behind the 10R80).
https://transmissionadapters.com/
Old Dec 3, 2025 | 07:13 AM
tecgod13's Avatar
tecgod13
What you need is a 4x4 E4OD, instead of the 2wd one you have.
Or the parts to change what you have to a 4x4 one, which would be a rear case, output shaft and I have no clue what else....
Old Dec 3, 2025 | 03:53 PM
Tillylamp's Avatar
Tillylamp
Originally Posted by Olds64
Wow!
hi, that link you put up doesn`t work for me, just comes up as blank.....yes, the output shaft is the last thing to be removed and swapped for a 4x4 shaft, i have emailed them for a price but still waiting....
Old Dec 3, 2025 | 04:09 PM
Tillylamp's Avatar
Tillylamp
yes, i know what i need and i had a 4wd e4od lined up but it fell through, then, i come across this adapter whilst searching on the web, it looked like a good mod that i could attach to my 2wd e4od, i was going to swap my 2wd trans with a t19 but i have had a change of mind, looking forward i would like to keep my truck an auto, these adapters were made by a company called quigley or something like that.....if anyone had one i would buy it off of them as my 2wd e4od is a good one.
Old Dec 3, 2025 | 04:53 PM
Olds64's Avatar
Olds64
Sure enough, adapters do exist. You might have seen this already.
https://www.sportsmobileforum.com/th...p-e4od.746789/
You can use this search engine to see if you can find an E4OD truck or van in a salvage yard near you.
http://www.car-part.com/
A coworker of mine found a Gear Vendors in the salvage yard (auxiliary over/under drive unit) for the C6 in his Mercury Cougar.
BTW, the link I posted works for me. Try this one.
https://transmissionadapters.com/collections/ford
Old Dec 3, 2025 | 06:05 PM
Tillylamp's Avatar
Tillylamp
Thumbs up
[QUOTE=Olds64;21713552]Sure enough, adapters do exist. You might have seen this already.
http://https:/www.sportsmobileforum....ap-e4od.746789
https://transmissionadapters.com/collections/ford[/QUOTE none of those sites have what i`m looking for, but thanks for taking the time to put them up mate.....
Old Dec 3, 2025 | 06:50 PM
Olds64's Avatar
Olds64
Good luck in your search.
Old Dec 4, 2025 | 10:21 AM
knottyrope's Avatar
knottyrope
https://forum.expeditionportal.com/t....223250/page-2
pics of the adapter
Old Dec 4, 2025 | 10:47 AM
Tillylamp's Avatar
Tillylamp
Originally Posted by knottyrope
thanks for that mate....
douglpr42
Ford Truck Parts for Sale
Mar 20, 2012 11:38 AM
turboman24
Jan 27, 2011 08:48 AM
leadmic
May 17, 2003 09:35 PM
