adding power steering
Old Dec 2, 2025 | 10:21 AM
hdman6's Avatar
hdman6
I have a I-6 240 engine in my 66 f100. Now that i have all the leaks repaired im thinking of adding power steering if its possible. Anybody know if there is a kit or if it can be done to my engine?
thanks for the replies. Jeff
Old Dec 2, 2025 | 11:03 AM
The Dassler's Avatar
The Dassler
I am sure I am not alone in saying..post some pictures, as they are worth a thousand words. Then I know someone will ask, what transmission and is it an automatic or three on the tree, or four on the floor, as this will determine if you should look for an original Bendix gear box, or consider a later Saginaw gear box.
For the record, I too would like to also add PS to my '66 F250, so I have been trying to become educated. In my case I have the Automatic and I want to keep the original steering wheel and column shift. That said, from what I have read, the Bendix box is closer to the size of the original unassisted steering box. Thus, minimal modifications have to be done to the steering column to fit the Bendix box. Likewise, I have read that the Saginaw box is 2+ inches longer and that can interfere with the three on the tree and Automatic shift tube. However, I have also heard that the Saginaw is better quality and more durable, and while I can't comment to the truth of that, it would be something to consider, but I will let someone else chime in on that to confirm or deny.
Point is, there will be lots of thoughts and you will have to decide what is best for you.
I will add... there was, a few months ago, a guy from the bump side forum marketplace, selling a fresh Redhead Saginaw box with everything you would likely need except maybe the pully and pump mounting point for your 240, I thought his price was fair, but after some thought, due to my trucks Automatic, passed and decided to look for a bendix box.
He may have sold it already, but if you have a four on the floor, it might be a reasonable way to go.
Good luck and keep us posted with what you decide to do and take lots of photos.
Old Dec 2, 2025 | 12:35 PM
Crop Duster's Avatar
Crop Duster
Easiest way is to find a donor truck up to 1979 and swap everything including the disc brakes. Everything you need to know is in these tech articles. Technical Articles Index - FORDification.com
Old Dec 3, 2025 | 08:19 AM
hdman6's Avatar
hdman6
Ok thanks for the help .
rwrogers
Ford Truck Parts for Sale
Jun 18, 2015 12:59 PM
jj292
Jul 10, 2003 05:00 PM
