Sponsored by: Innova
Radio resets during longer cranking
Old Dec 1, 2025 | 09:52 AM
Island Time's Avatar
Island Time
I have a 92 Ford F250 with the 7.3l diesel engine. The prior owner has already installed an aftermarket stereo which I’d like to replace. One problem to resolve is the stereo resets during longer cranking, like when it’s cold outside, which causes the Bluetooth setup to be lost. The battery is newer and in good condition. Does anyone have suggestions for either a fix, or an aftermarket stereo which is less susceptible to this problem?
Old Dec 2, 2025 | 06:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like he has the keep alive memory power hooked to the wrong circuit
Old Dec 2, 2025 | 10:11 AM
Island Time
I hadn't thought about that. The PO is a really great guy, but doesn't know much about wiring, so that could be it. If so, it's an easy fix. I'll try to get that checked out today.
Old Jan 20, 2026 | 03:46 PM
madsonp's Avatar
madsonp
Sounds to me like the battery maybe in a weak state, just because it’s “newer” doesn’t mean its good. I suggest having a load test done on the battery to determine it’s condition, then if it tests good I suggest you clean your battery terminals real well incase they’re dirty as that could also cause the issue you’re seeing, and see what that does for you.
Old Jan 20, 2026 | 06:22 PM
Island Time
It did it with a new battery. It's just a heavy old diesel that requires longer cranking in the cold weather, 5-10 seconds, even after the glow plugs are up to temperature.
axelthrasher
May 4, 2024 02:43 PM
Highboosted
May 10, 2019 11:17 PM
eazrider
Sep 24, 2013 04:00 PM
Keoki
WTB - Parts & other
Jan 22, 2013 07:23 AM
cbradford
Jul 1, 2008 08:36 PM
