Sponsored by: Real Truck
250 vs 350 specs
Old Dec 10, 2003 | 03:02 PM
nextel_cup_fan's Avatar
nextel_cup_fan
not sure when they changed, my 88 250 independent front end ate up tires
Old Dec 10, 2003 | 03:43 PM
superdutyspv's Avatar
superdutyspv
My stock tires on my 250 are T265/75Rx16E. I have a 2000 F-250.
Old Dec 10, 2003 | 03:51 PM
camo4stealth's Avatar
camo4stealth
I believe the front axle on the SD F-250 is actually a Dana 50.
Old Dec 10, 2003 | 03:57 PM
78f3504x4's Avatar
78f3504x4
The Dana 50 was discontinued, from 2002-up F250 and F3504x4 have a Dana 60 front.
Old Dec 10, 2003 | 06:41 PM
Mwachel's Avatar
Mwachel
The 250 has the 2 inch blocks in back and the 350 has 4 inch.
EVERYTHING else can be had on both trucks. You can get either set of tires for the 250.
Old Dec 21, 2003 | 02:48 PM
aldridgec's Avatar
aldridgec
Originally posted by 78fordman
Are they full floating or semi floating?
By virute of design any front 4x4 axle is full floating.
Old Dec 21, 2003 | 04:23 PM
rimshoes's Avatar
rimshoes
Hey, I'm a horsey person too. I bought an F350 DUALLY, The one ton capacity does make a difference when you are towing big 4 horse goosenecks with all that wieght in the bed of your truck. The truck is great and when your hauling you do not get white knuckles when that semi goes by at 80 + or when you mare and stallion decide they should try to mate in the back of your trailer. The axle on the dually is huge. Do not know about the brakes, buti if you can get the torqueshift 5 speed auto tranny in your package DO IT. The tow/haul switcht is wonderful and it works in all 5 forward gears damn near down to 5 MPH. Hope this helps. rimshoes.
Old Dec 21, 2003 | 04:29 PM
garyle's Avatar
garyle
don't forget the emblem...blocks and emblem. The blocks are for correct headlight alignment with the xtra gvw.
Pierce Newsom
New Member Introductions
Apr 1, 2015 03:51 PM
almostgone
Jun 24, 2012 07:31 PM
jsgoss02
27
Feb 17, 2008 09:30 PM
thexman
Aug 25, 2006 12:07 PM
CLA4JC
Jun 30, 2006 12:00 PM
