CP4 Failures
I was also meticulous about maintenance, using fuel additive, etc! Yup, FoMoCo warrantied it; but sorry, all parts are on national backorder!
You have a trailer sitting with a load of household goods, putting up a moving crew in a hotel, etc. Yup, very few fail, but WHEN it is YOURS you get a whole new perspective!
Of course now I don’t have a truck of any brand for the first time since about 1961!
And FWIW, I couldn't agree with you more about your last point. So while many will say that it hasn't happened to them and that it's rare, I'm a guy who always errs on the side of safety, or in this case overkill, by using my "snake oil" additive of choice every tank because, Murphy is always right and my luck is usually never good.
Meticulous maintenance by me, additive every tank, good turnover stations.
Fortunately Ford covered under warranty.
My daughters 17, same conditions dumped also (about 18 months earlier). Warranty denied. I personally looked at the parts, no rust no water.
A good friend out west was in the market for a “new to him” truck. He asked me about the 19 F350 w/service bed he was looking at. We went through it and it looked solid. As I recall it had about 60k on it. I told him about the “potential” CP4 issue. He bought the truck and we put a DPK on it the next day. Fast forward 3 months he was 200 miles away and the cp4 went disco.
We loaded it up. Brought it back.
Replaced all the filters. DPK caught everything ordered and installed a DCR called it a day (weekend actually)
His words “this truck runs so much better”.
It wasn’t a fuel issue, he has his own 5,000 gallon tank he uses on the ranch. The fuel issue always fresh.
My has a 16 w/106k. He has a DPK we put on at the same time as mine.
What I have found interesting is all the research, monitoring and conversations I have had with 6.7 people (like All of us) I really don’t see a ton of pre-17 trucks with CP4 issues. I know they are out there, just don’t hear about them much. Unlike us aluma duty people we can’t shut up 🤐.
For me, this is my forever truck. I will most likely put a DCR on it at some point. My wife is just waiting to see the purchase ! (Gotta love her). For now change the filters, use a quality additive, find high turnover fuel station and above all enjoy your truck !
Ford has the data on failures on a general scale. The “biodiesel” fix is a joke and we all know it.
Just my thoughts !
Enjoy the weekend.
ZooDad
Let me know if this link below works. If not, I will copy and paste.
https://www.bing.com/ck/a?!&&p=cf4a2...aW1wYWN0LnBkZg
EMARecommendFuelProperties.pdf
Another link, though for Archoil, that explains this subject.
How to Improve the Lubricity of Diesel Fuel | Archoil
Another good article on lubricity and diesel fuel.
Diesel Fuel Additives, Part 2: Lubricity Facts and Fictions - Professional BoatBuilder: An IBEX Technical Journal
Last edited by Overkill2; Dec 6, 2025 at 07:49 AM. Reason: add to post a second time
Just my thoughts !
Enjoy the weekend.
ZooDad
On another note, it is good to hear the DPK did its job, and it is further evidence that at a minimum, we should have one installed.
Yes, good to hear the 2nd Gen S&S kit did its job and protected the rest of the fuel system. Makes me feel good I have mine installed.
when I went to florida two years ago from nyc....I was stuck in the mud for about 3 weeks due to unrelated confusing error codes and wrench light that put my truck into reduced power mode. ford in a 100 mile radius has no appts for 3 months so that meant my 7yr / 125 k warranty was worthless.
started replacing parts and it turned out to be an ebp sensor.
back to cp4. yes...no doubt it will fail when you dont expect it with your family and goods on board....death of night...freezing wet weather...on a road with no street lights and no dry ground.
so you put in a dcr and should be good to go....
or if you are in the early bird react to internet chatter crowd...you have a dpk, which has been demonstrated to keep your truck drivable while the cp4 cam and roller bearing self destructs ....that way you can get off the highway that has traffic going 80 mph , no street lights, and the worse weather you can imagine.
so I have not noticed the 2017 and later being worse than the 2016 and prior.....it could be the case. I do know that the 2017 and later were supposed to have a secret sauce coating on the cam lobes or roller bearings or both. and the 2020 and later pinned cups.
I read somewhere that even if you ran straight oil in the cp4, once the cups rotate...your done
I would do some serious Yogi level Irish Yoga to not pull my cab FYI.
