SPE CP3 Conversion?
Old Nov 30, 2025 | 12:08 PM
rufushusky's Avatar
rufushusky
Originally Posted by chadstickpoindexter
But we can ask this about any business...?
Bosch is in significantly better shape than stanadyne, PE has picked it pretty clean.
That said if S&S did their homework they should have right of first refusal on the IP of the DCR based pump and could possibly replicate with a contract manufacturer.
Old Nov 30, 2025 | 12:13 PM
Overkill2's Avatar
Overkill2
Didn't some automakers require some financial help, right or wrong, that are still here?
Old Nov 30, 2025 | 03:19 PM
kayakingpoodle's Avatar
kayakingpoodle
Is the naming convention still applicable, will the CP8 have 8 pumping events per revolution like the Cp3 's 3 per and the Cp4 's 4?
Old Nov 30, 2025 | 04:21 PM
chadstickpoindexter's Avatar
chadstickpoindexter
I haven't read through all of it, but here is an article on the CP8. I do wonder if Ford will adopt it, or even if it will be backwards compatible, but at this point isn't it just RAM using it... let them work all the bugs out I guess! It will be interesting to see how it does though.
https://www.kemsoracing.com/blogs/ne...He47zH8GLwiYzl
Old Nov 30, 2025 | 04:29 PM
kayakingpoodle
https://www.kemsoracing.com/blogs/news/cp8-fuel-pump-the-critical-high-pressure-heart-of-modern-diesel-engines?srsltid=AfmBOoqnrjA4iufe8dfmKN6EUsk2stvjF1 6xjpQOhxHe47zH8GLwiYzl
From the article it appears the cost after failure is still going to be high
Quote:
" The entire contaminated fuel system must be addressed. At minimum:Replace all fuel injectors with new units.Replace the common rail.Replace the fuel filter housing and install a new filter.Thoroughly flush all fuel lines with clean diesel.Drain, clean, and flush the fuel tank, or replace it if debris is extensive.Replace any potentially contaminated sensors in the high-pressure circuit.Use fresh, high-quality diesel fuel."
Sure doesn't appear they have the faith in the new pump to warranty a pump swap without doing a full system 😞
Old Nov 30, 2025 | 04:35 PM
chadstickpoindexter
It looks like it is not a new pump either...
  • Widespread Adoption: The CP8 has become the dominant high-pressure pump on many European diesel engines introduced from approximately 2015 onwards.
Old Nov 30, 2025 | 05:03 PM
FishOnOne's Avatar
FishOnOne
If this pump is reliable in the Ram cummins application, it should be a good pump. Reason I say that, the implementation of the CP4.2 pump for the Ram cummins was overdriven and were dropping like flys.
Old Nov 30, 2025 | 05:18 PM
kayakingpoodle
Are they still overdriving them?
Old Nov 30, 2025 | 06:38 PM
FishOnOne's Avatar
FishOnOne
Not sure, but with two pistons I suspect they still are unless they increased the volume of the cylinders
Old Dec 1, 2025 | 01:16 PM
kayakingpoodle
Or added lobes, the cp3 is 3 pumps 1 lobe, the cp4 is 2 pumps 2 lobes, we know the CP8 is 2 pumps, but how many lobes
Old Dec 1, 2025 | 01:45 PM
JoeUser's Avatar
JoeUser
The way they keep pushing up fuel pressures I wouldn't be surprised if they eventually manufactured a little Wankel engine to mount on the front of the block to pump the dang fuel... lol
Old Dec 1, 2025 | 03:37 PM
rufushusky's Avatar
rufushusky
As long as they make the low pressure side of the pump oil and not fuel lubricated I couldn't care less how they do it.
Old Dec 1, 2025 | 03:53 PM
  #28
FishOnOne's Avatar
FishOnOne
Bosch installed something similar to the back side of the CP4.2 used on the Duramax to pump fuel into the CP4.2 pump. This worked fine until the filter change and this pump went dry therefore starving the CP4.2 for a bit. That was a bad design.
Old Dec 2, 2025 | 08:00 AM
  #29
Overkill2's Avatar
Overkill2
IMO, it appears Stanadyne isn't going anywhere anytime soon.
Diesel and Gasoline Fuel Injection Systems - Stanadyne
Diesel Products - Stanadyne
Old Dec 2, 2025 | 08:28 AM
  #30
rufushusky's Avatar
rufushusky
No I don't think they are at risk of a going concern issue but their majority shareholder is Cerberus, the same group that parted out Chrysler post DC break up. Additionally, they successfully reorg under Chapter 11.
Just for context, stanadyne has produced 46 million injection pumps in almost 75 years..
Bosch has made over 60 million CP4s alone.
https://www.bosch-mobility.com/en/so...sure-pump-cp4/
So there is a significant difference in scale here, that said if S&S played their cards right even if Stanadyne goes toes up they should be able to get their hands on the underlying IP of the pump. Won't be cheap but should allow them to continue production.
