Rear View Mirror Sensor
Old Dec 18, 2025 | 12:25 PM
uzzirider's Avatar
uzzirider
6th Gear
Yes, I've retained the ambient light sensor that faces the windshield. The driver facing sensor is blocked, but who cares cause that particular sensor apparently only affects autodimming of the OE rearview mirror (which is now replaced with the wolfbox). I did play around with mounting areas like the headliner and found what I think is the least ridiculous. The logic board is actually rotated 180, so it's sitting upside down. Still ridiculous, but less than the other options.
Yes, after installing the wolfbox and prior to doing this ghetto-mod, I found that the dash lights were super dim upon startup, then would eventually brighten up while driving. This truck isn't my daily, so I haven't spent enough drive time to determine if this ghetto solution totally rectifies the autodimming. Hopefully I can put some miles on the thing soon.
Old Dec 28, 2025 | 04:23 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Since this thread was started in November of 2025, I noticed that FTE Sponsor @Wolfbox announced a Firmware Update (v1-6-3_251103) for the Wolfbox G900 Tripro Dash Camera as posted on November 14, 2025.
The firmware appears to have been released on November 3, 2025, if I am interpreting the numerical code at the end of the version revision number correctly.
While the update won't house Ford OEM equivalent sensors back in place, it is at least useful to know that Wolfbox can and does update the product via firmware revisions.
Therefore, if there are any other user and useabilty suggestions that Wolfbox should listen to, that could potentially be resolved by firmware, consider reaching out to Wolfbox via PM or via the thread link in the sentence above, to provide your input.
Old Dec 28, 2025 | 07:22 PM
dougcjohn's Avatar
dougcjohn
That’s correct, the Wolfbox units can be updated, and within the mirror’s menu you can select to ck & update firmware.
To work with Ford or other manufacturers light sensor for dash lights, Wolfbox would need to add a sensor and compatible interface plug.
Or include an enclosure mount to mount Ford’s light sensor circuit board… I’d prefer the first option where they provide the light sensor interface.
I was considering reaching out to Wolfbox on sensor interface question.
Old Jan 4, 2026 | 12:37 AM
Wolfbox's Avatar
Wolfbox
PREMIUM SPONSOR
Thank you my friends, for supporting and discussing our products. Sorry I didn't see this thread until now.
I'm happy to answer some questions here. I'll start with:
  1. Wolfbox dash cam doesn't equip with auto-dimming. You need to change the screen light manually in the setting.
  2. Regarding the needs for RV owners about the wireless cams, yes, we hear you.
  3. Wolfbox dash cam can be used as backup camera if you connect the rear cam correctly. Normally, red wire to the positive pole.
__________________
Wolfbox enhances the driving experience with vibrant and reliable automotive electronics.
Dare to Go EverywhereFacebookInstagramYouTubeReddit
Customer Service: service@wolfbox.com
Old Jan 4, 2026 | 05:03 AM
OX2's Avatar
OX2
Do you have a version that can use 3 external cameras.
IE, both sides and rear of a trailer? (does not have to be wireless).
Old Jan 4, 2026 | 08:48 AM
dougcjohn's Avatar
dougcjohn
Thanks for joining the thread. I sent an email eariler mentioning our forum discussion.
You indicated in email that you didn’t have solution currently to house the OEM light sensor board.
As a possible cross platform enclosure, would be great if you could integrate a small thin enclosure box that would fasten to the back of your Mirror. Even if Owner needed to modify: cutting connector plug, foam tape to secure board internally. Mainly an enclosure that attached to your mirror would be very helpful.
Old Jan 4, 2026 | 09:06 AM
powerboatr's Avatar
powerboatr
Let me ask the dumb question
could we simply mount the wolf box rear view below the factory and just keep it on as a live camera view..similar to what we do in our rv bus
Old Jan 4, 2026 | 09:57 AM
dougcjohn's Avatar
dougcjohn
You technically could by simply adding a 2nd windshield glass mount base. You can easily mount to Ft of OEM Mirror like most digital mirrors and the light sensor remains on OEM mirror.
Old Jan 5, 2026 | 03:32 AM
Wolfbox's Avatar
Wolfbox
PREMIUM SPONSOR
It's in our plan.
__________________
Old Jan 5, 2026 | 03:34 AM
Wolfbox's Avatar
Wolfbox
PREMIUM SPONSOR
Maybe our colleague at customer center talked with you. Thanks for your advice. We'll keep improving our product. Cheers!
__________________
Old Jan 5, 2026 | 03:36 AM
Wolfbox's Avatar
Wolfbox
PREMIUM SPONSOR
We have this center console base mount for mounting. Check it out please.
__________________
Old Jan 5, 2026 | 05:08 AM
OX2's Avatar
OX2
It's in our plan.
Well, hurry up..........
backing my 30 foot enclosed into my pole barn was a nightmare I will not repeat, without some form of cameras.
explorer003
Oct 4, 2021 02:42 PM
Seven Gables
Jul 8, 2017 07:55 PM
WillyD865
Oct 15, 2012 07:41 AM
scrug213
Apr 25, 2008 06:39 PM
chopper chik
Jan 25, 2006 11:14 AM
