Gremlins gone...
Old Nov 22, 2025 | 07:24 PM
JamesAConant's Avatar
JamesAConant
Trailering
Arrow Gremlins gone...
Ok, I've been have been chasing gremlins in my fuel system. Good News: Cured!! I got tired of my truck not running right, hard starting and losing prime. What did I do to castrate the gremlins? Started at the fuel line at the selection valve and installed a anti-back flow valve / removed the mechanical fuel pump and block plated the block, installed a Facet-Purolator / Facet Drra-Lift fuel pump / replaced the compression gaskets on the discharge fuel line from the filter to the injection pump / replaced all the plastic caps, o-rings and return lines / disconnected the return line from the filter to #1 injector housing and plugged... The truck now starts like it's supposed to, runs great and have the hesitations any longer.... I picked up 12v power from the pre-heater hot side (on only with the ignition switch activated), installed a inline fuse system... NOTE: All fuel line clamps are fuel line style, not standard screw type hose clamps... Thanks to everyone that has posted fuel problems here, they were a great help and gave me as lot of input and good ideas...
TO EVERYONE OUT THERE... HAVE A GREAT THANKSGIVING, CHRISTMAS AND NEW YEARS...
Old Dec 8, 2025 | 10:05 PM
Leroy Unlisted's Avatar
Leroy Unlisted
Awesome !! - IDI is brick St*t house reliable, but they sure attached, to her, a wimpy fuel system to drink from, fuel system rebuild is a winner !
Old Dec 9, 2025 | 08:20 AM
WCMtn1990's Avatar
WCMtn1990
Also, the Facet Dura-Lift pumps have a built in check valve so installing another one isn't absolutely necessary.
rlwilson2
22
Jun 20, 2010 08:22 AM
89F20plowtruck
May 18, 2010 04:52 PM
74baja
Oct 15, 2009 07:43 PM
jtharvey
19
Jun 5, 2006 07:37 PM
