Fuel Pump replacement questions.
Old Nov 22, 2025 | 10:20 AM
Pyromedic65's Avatar
Pyromedic65
4th Gear
Question Fuel Pump replacement questions.
So here's what I'm dealing with and need some input from others that have had similar problems or had to replace a fuel pump. I have a 2019 F250 6.2 Flex Fuel. I started having performance issues that pointed to a possible bad fuel pump. (Won't go into detail because it turned into a laundry list of problems) The biggest obstetrical was replacing the fuel pump.I bought a new pump off of Amazon for close to $100 (Might be mistake #1). I swapped it out with the old one and for three days there was a noticeable difference in truck. Better performance, shorter crank times, much less stuttering up hill. Literally after three days of working fine I went to start up on the fourth morning to take my kids to school and the truck turned over for a second or two, died, and would not longer fire up, but would still crank with no issue. I buddy of mine suggested that possibly the pump being aftermarket needed to be reprogrammed in the computer to "relearn" the desired pressures and performance. I haven't had a chance to try this, but this doesn't sound like the issue to me. What it sounds like is I cheapened out on a bad pump and this is my punishment. My question to y'all is, did I overlook something before going down a second replacement pump? Fuses are good, starter is good, pump appeared to be priming when the key was turned, just didn't seem to be of a high pressure, but I have no way of testing this.
Old Nov 22, 2025 | 11:38 AM
jimzpsd's Avatar
jimzpsd
For what its worth.....I would replace the pump with new OEM or better. The $100 pump sounds like its trash already, and even if the oem pump doesn't fix your problem, its still nice to know its "not" the pump. A fuel pressure reading will tell if the pump failed. But I would still swap it out with better quality.
Old Nov 22, 2025 | 01:47 PM
drj564's Avatar
drj564
I”ve seen many YouTube vids of mechanics I trust chasing down issues where aftermarket parts or counterfeit parts were installed by the owner. I always try to replace with known OEM parts even if it means getting them from the stealership.
Old Nov 22, 2025 | 03:46 PM
HorizontalHunter's Avatar
HorizontalHunter
This. Gotta be carful with Amazon parts. Lots of fakes out there. The OEM fuel pump is close to $500.
The age old expression is as true today as it was all those years ago: If it seems too good to be true …..It probably is.
Bob
TunaCat
6.7L Power Stroke Diesel
Aug 27, 2024 12:34 PM
ssmorsi
1997 - 2003 F150
Apr 8, 2012 06:45 PM
DAI532
27
Sep 24, 2009 08:34 PM
audimaster
Jun 13, 2007 09:31 AM
irishguyincc
1983 - 2012 Ranger & B-Series
Jun 5, 2006 01:28 PM
