302 engine
Old Nov 19, 2025 | 10:16 AM
48ford///'s Avatar
48ford///
Trailering
Angry 302 engine
Does anyone out there know where I can find a good oil pan for my 1979 truck 302, mine has been repaired to many times now.
Old Nov 19, 2025 | 10:38 AM
ranger140892's Avatar
ranger140892
Grumpy goat
A Fox body oil pan should work. You can get OEM, aftermarket, or used ones.
Old Nov 19, 2025 | 12:15 PM
48ford///'s Avatar
48ford///
Trailering
the oil pan I am looking for has a front sump and drain plug at back of that sump, on a truck, drain has to be at back of pan so you can get at it. tks
Old Nov 19, 2025 | 12:39 PM
ranger140892
Grumpy goat
Yeah, the Fox oil pan may not work for you. I have installed one in a 6th gen with 302. It's been a long time since I did it, and I'm probably forgetting some details that are showstoppers for your situation. The Fox oil pan has front and rear sumps, both with drain plugs. The rear sump is the larger one, and is also where the oil pump pick up is. The front sump's drain is at the front, which may not work for you. The center of the pan is is raised for K member / suspension clearance.
https://www.summitracing.com/parts/r...-022/make/ford
https://www.summitracing.com/parts/m...span/make/ford
Old Nov 19, 2025 | 01:00 PM
ranger140892
Grumpy goat
Did you look at Bronco Graveyard?
https://shop.broncograveyard.com/197...uctinfo/20170/
Cliffdog
Mar 2, 2005 09:32 AM
monkei
Sep 10, 2004 08:11 PM
pinegreen
Nov 15, 2000 08:17 AM
arapco
Nov 10, 2000 02:49 PM
