Really need help with diagnosing
Old Nov 15, 2025 | 04:53 PM
DentsideFan's Avatar
DentsideFan
I have a 1978 F-250 351M C6 auto NP205 4x4 and it makes a really bad whirring and grinding noise when I'm in any drive gear R D 2 1 N and P are quiet and I can hear the whirring slowly go down and it doesn't whir unless in the gears and I'm moving. I can feel it through the transfer case stick and can hear it outside the truck when moving ATF doesn't smell burnt or wrong. Transfer case is full of fluid and correct not much to go wrong in those cases and it moves fine into 4H or 4L or 2H. None of the front hubs are locked and I moved all tires individually and they didn't make noise. And it goes with Engine RPM when in drive gears higher RPM louder it is. And all gears shift crisp and clean.
Here's a video of the whirring/whining sound.
File Type: mp4
Old Nov 15, 2025 | 06:30 PM
440 sixpack's Avatar
440 sixpack
There are a lot of things it could be, but with nothing but 4 seconds of video to go on the pump in the transmission would be my first guess.
Old Nov 16, 2025 | 12:24 AM
Wangdangdoodle's Avatar
Wangdangdoodle
In gear and moving? Check your speedo cable.
Nevermind, just listened to your video.
Old Nov 16, 2025 | 08:46 PM
motorsickle1130's Avatar
motorsickle1130
Have you pulled the pan? Hopefully a grenade didn’t go off in there.
Old Nov 16, 2025 | 10:32 PM
1TonBasecamp's Avatar
1TonBasecamp
Sorry, but I don’t hear a thing extra in the video. Just the engine running.
But your description sounds almost like the parking pawl is only half engaged. Or I should say (because it doesn’t do it in park or neutral), is only half disengaged.
Flareside Ford1234
Apr 21, 2021 11:01 AM
fjordtruck
2004 - 2008 F150
Sep 18, 2020 03:21 PM
Cougar2
74
Mar 5, 2020 02:11 PM
jereli
Nov 20, 2016 10:49 PM
78 Cattletrk
Dec 14, 2003 08:00 PM
