I pulled my 302 engine out of my 1979 F-150 because of a leaking head gasket, when I removed exhaust manifolds I didn't notice any gaskets for them, did I miss something.
so when I reinstall manifolds, do not use gaskets, maybe they are not available for my engine???.always thanks
hundreds of avail gasket for your engine. If you are putting the same manifolds on again they are not needed as stated. If you have leaks, after properly tightening and going through a couple heat cycles you can always put on a gasket.
