1977 rear shock replacement?
Old Nov 14, 2025 | 02:17 PM
crybaby's Avatar
crybaby
7th Gear
Hi, im inexperienced and have no one to ask so im turning here for help. ive got a 1977 ford f250 , 2wd, 460. One of my rear shocks is completely broken, just hanging not even attached to anything, so im going to replace them both, was wondering if you guys could point me in the direction of what exact shocks i need that will fit this truck, i really appreciate any help
Old Nov 14, 2025 | 03:50 PM
scottscott's Avatar
scottscott
According to my old Monroe catalog, you will be looking for Monroe part #'s: Magnum 6825, Monroe-matic 2080, or VIP 8032. Listed best to cheapest. Start searching those #'s on eBay.
Before you buy anything, slide under the truck & make sure that the upper shock mounts are not rusted off & broken. It is very common for the upper mount to rust & break, leaving the top of the shock flopping around.
Old Nov 14, 2025 | 05:49 PM
mac.motorworks's Avatar
mac.motorworks
agree with Scottscott.. take some pictures and post here. We'll be able to get better advice
Old Nov 15, 2025 | 11:52 AM
beartracks's Avatar
beartracks
Ditto
Old Nov 15, 2025 | 01:36 PM
Rubiranch's Avatar
Rubiranch
I went with Monroe's lightest duty shocks for my 1976 F-250 4wd because it rides like an old Dodge 1-ton.
And the last thing I wanted was something that might stiffen up the suspension even a tiny little bit.
Try https://www.rockauto.com/
Old Nov 17, 2025 | 02:39 AM
crybaby's Avatar
crybaby
7th Gear
Old Nov 17, 2025 | 02:42 AM
crybaby's Avatar
crybaby
7th Gear
I think you're right, I got under it today and just posted some pictures. I can see a little rust around the hole and looks like the top of the shock slipped through
Old Nov 17, 2025 | 03:37 PM
scottscott's Avatar
scottscott
I think you got lucky, your mounts are fine, as are the shocks.
What you need are new bushings. You'll remove the nut on the top of the shaft coming out of the shock, remove the washer, what looks like a sleeve, & the lower bushing. Install a new washer & lower bushing, pull the shaft out of the shock so it sticks thru the hole in the frame bracket. Install a bushing on top, washer, then the nut. Tighten the nut, you're done. This is what the new bushing should look like, I don't know if this would work for your application. https://www.ebay.com/itm/40611764221...Bk9SR8auqrvSZg
To get the correct bushings, I'd measure the diameter of the shock shaft & the hole in the frame mount. Go to a good auto parts store, like a NAPA that's been around for 40 years. Tell them you need shock bushings & washers, give them the measurements. Hopefully you get an old guy that knows how to look up parts & they can fix you up.
If you are ambitious you can take the lower bolt out of the shock, remove the shock, & take it to the parts store so they can fit a bushing directly on the shaft.
Get two sets of bushings, the other side will fail soon & need replaced.
Old Nov 17, 2025 | 04:40 PM
tbear853's Avatar
tbear853
Looks like someone did not even put a bushing cup washer on the top side of the bushings, should never have been able to pull through the mounting hole of the mount.
Old Nov 17, 2025 | 08:28 PM
crybaby's Avatar
crybaby
7th Gear
What you need are new bushings. You'll remove the nut on the top of the shaft coming out of the shock, remove the washer, what looks like a sleeve, & the lower bushing. Install a new washer & lower bushing, pull the shaft out of the shock so it sticks thru the hole in the frame bracket. Install a bushing on top, washer, then the nut. Tighten the nut, you're done. This is what the new bushing should look like, I don't know if this would work for your application. https://www.ebay.com/itm/406117642213?_skw=shock+absorber+rubber+bushings&e pid=230275941&itmmeta=01KA9VAJWR2ZDERQD3ZKDYNQCH&h ash=item5e8e7f6fe5:g94AAeSw78loltPK&itmprp=enc%3 AAQAKAAAA4FkggFvd1GGDu0w3yXCmi1dhrCK5E10NgB1YqTsxw J8aTdxXHmfVnsrqmGdbX%2BquF%2BPTV1tVf2Ah9SH6MFROUHy BqdhhEwSo%2FlFt9mEQlJindK2YVQeiKoLoPqXPcJSBmOsYn %2FOFPNfq4x9cbVHkXF3mILK7gLxCI90BSKq0j7RPwABZ97vI0 JBkNCqW11p5VEF6EaObBjVYv2fDQB53F%2FOi4pLH9A%2B6bGr YUmUhmK472toGVrmGtPzNSa5g%2BTqxFmBsZIJZ4pVm3NqTgGX qi0IVra4RX9SYvIBV7iIQmP%7Ctkp%3ABk9SR8auqrvSZg
thanks I really appreciate the advice, glad to hear the mounts look fine, it's been raining here but when it dries up I'll get under and triple check. I think I might just go ahead and replace the shocks , rock auto has this set sold as a pair, comes with the bushings and everything I need right? Strut etc it's the whole assembly? It also says they're 'load adjusting' , is that good for these trucks? Sorry for all the questions
Old Nov 18, 2025 | 03:59 PM
scottscott's Avatar
scottscott
I wouldn't use those shocks. They have a spring on them which will make a rough riding truck even worse.
Old Nov 18, 2025 | 04:54 PM
tbear853's Avatar
tbear853
I agree, you do not need those with springs on a '77 250 unless you're gonna be hauling stove wood racked up higher than cab roof.
I recently replaced rears with yellow Monroe 34911 Gas Magnums (34901 were for 4wd rear), just shorter than the ones that have been on it a good 30 years. after lowering the rear to 2wd height.
Old Dec 5, 2025 | 12:46 AM
crybaby's Avatar
crybaby
7th Gear
i just wanted to come back and say thanks, I took all the advice and replaced them really appreciate it
https://www.tiktok.com/t/ZTraN6VYe/
wld427
2004 - 2008 F150
Apr 3, 2022 04:50 AM
alchemist1
Jan 27, 2014 10:12 PM
week0019
2004 - 2008 F150
Jul 26, 2011 12:07 PM
Jetsfan68
Jan 22, 2004 09:50 PM
Poolpro
Jul 30, 2003 03:23 PM
