Lurching into gear
Old Nov 14, 2025 | 02:09 PM
walter1991's Avatar
walter1991
4th Gear
Lurching into gear
Hey forum, first post here. I have an 89 F150 2WD 4.9L C6 with 198k miles.
When I put it into gear, it lurches terribly (D forward lurch, R rearward lurch). Check out my videos of the driveline from transmission back. It doesn’t look like the transmission is moving so I’m thinking it may be the differential? What do y’all think?
Old Nov 14, 2025 | 02:11 PM
85e150's Avatar
85e150
What is your idle speed?
Old Nov 14, 2025 | 02:15 PM
walter1991's Avatar
walter1991
4th Gear
I have no idea, no tach or tool for that. Does it sound high?
Old Nov 16, 2025 | 07:19 AM
walter1991's Avatar
walter1991
4th Gear
Bumping to hope for more help.
It does go to high idle on cold crank and settles down after it heats up. I don’t know what it settles to though. Is the thought that my engine/transmission mounts are bad?
would appreciate any help thanks!
Old Nov 16, 2025 | 10:15 AM
wwhite's Avatar
wwhite
To me looks like your suspension is bad.
Your shocks are toast, and more than likely the springs are worn out.
Looks like real bad axle wrap happening at idle.
Old Nov 19, 2025 | 08:18 AM
walter1991's Avatar
walter1991
4th Gear
thanks for the reply. I think the leafs themselves are okay but I will look into the bushings and all the rubber bits that can go. I’ll see about changing the shocks too, they seem stiff rather than sloppy though.
4wheelsandahitch
Feb 23, 2022 04:51 PM
dcbullet
Jan 24, 2006 01:33 PM
Jimi62
Oct 25, 2005 05:34 PM
chrisw23
Jan 2, 2002 12:47 PM
