MAF sensor
Old Nov 12, 2025 | 02:46 PM
PetesSuperduty's Avatar
PetesSuperduty
3rd Gear
MAF sensor
I had a code come up for maf sensor, I inspected and found a cracked cold air hose Crack. I replaced the hose and cleared the code. Today another code came up too much air and egr excessive air flow. I replaced the maf sensor because the truck was running fine after I unplugged the harness. Drove about 20 miles and unplugged the sensor and truck still runs fine, codes are cleared and no cel. But the codes are permanently stored in ob2. Shouldn't the truck shut off when I unplug the maf sensor?
Old Nov 12, 2025 | 02:58 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Nope, it'll run all day long without the MAF plugged in, but fuel economy may be in the toilet.
Old Nov 12, 2025 | 03:23 PM
PetesSuperduty
3rd Gear
fuel economy is great about 20mpg
Old Nov 13, 2025 | 01:56 AM
speakerfritz's Avatar
speakerfritz
Egr codes use MAF data
when egr opens, MAF is expected to drop
perm codes can’t be manually cleared…the pcm clears them once the code condition is verified as resolved.
i dont understand what you are doing.. nothing on a 6.7 is fixed by disconnecting sensors , driving with unconnected sensors, then reconnecting sensors.
Old Nov 14, 2025 | 10:16 AM
PetesSuperduty
3rd Gear
I disconnected it to see if the truck would stop running to check if the maf was bad, but plugged it back in. I changed the maf and so far light stayed off.
cj45lc
6.7L Power Stroke Diesel
Sep 20, 2022 01:43 PM
cj45lc
Sep 18, 2022 09:40 PM
xaos
Jun 6, 2022 05:49 AM
bob8619
Apr 22, 2012 03:58 PM
eldo
3.8 & 4.2L V6
Aug 18, 2004 03:30 PM
