"Highliner" Headliner Compatibility
Old Nov 11, 2025 | 05:53 PM
Ty1erG's Avatar
Ty1erG
Trailering
I came across a Highliner headliner on FB marketplace for $150. Considering they're $500+ new that's a helluva deal, but, it came out of an 82' F100 regular cab. I have a 78' F250 regular cab, anyone know if they're interchangeable or what it'd take to make it work? The pic is from the ad listing
Pic from the ad
Pic from the ad
Old Nov 11, 2025 | 08:05 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
So you are looking sort of at one this? https://www.lmctruck.com/interior/he...lt-in-speakers
79 versus 82, IMO not that much change in the that area. Get the seller to take some basic measurments like over all length and width. Then compare that to your 1979 head liner measurements.
Old Nov 11, 2025 | 08:18 PM
Ty1erG's Avatar
Ty1erG
Trailering
That's the one. I did request measurements, still waiting lol. Figured I'd hop on here in the meantime. Do you have any experience with it? *never thought id ask that in regards to a headliner
Old Nov 11, 2025 | 08:49 PM
77&79F250's Avatar
77&79F250
I think if that one measure's out the same as a 73-79 OEM headlinerand the edge lip looks like the 1979 headliner trim will match up (to hold it in place), you will be ok. Wiring the speakers...you will need to pull the wiring up thru the A pillar, if you use the dash radio. Or are you going to mount a radio up in it? Dvr side A pillar has the dome light wiring in it already. Also looks like you have a extra center dome light, should be able to tap into the OEM dome light wiring. I have not installed one.
Old Nov 11, 2025 | 10:48 PM
tbear853's Avatar
tbear853
I wanted one after seeing them in J C W for a hair over $100 long ago, more so after seeing one in a truck, but things were tight then. I did not realize the $$$ jumped so.
Old Nov 12, 2025 | 03:24 AM
Ty1erG's Avatar
Ty1erG
Trailering
Thanks for the diagrams! They'll definitely come in handy. Im thinking ill keep the stereo in the dash and install a cb overhead instead(recently acquired a whelen sa315 PA speaker&#128520 but definitely plan to run auxiliary power and ground terminals regardless...just because they're never in the way and always handy
dynamic
396
Nov 2, 2025 05:14 PM
1KILLERZ
Feb 17, 2017 05:38 PM
Adriand
Ford Truck Parts for Sale
May 19, 2015 09:54 PM
Mental
Aug 22, 2012 11:39 PM
