Sponsored by: Real Truck
Coolant Temperature issue
Old Nov 9, 2025 | 01:01 PM
92blackandblue's Avatar
92blackandblue
4wd Low
Two weeks ago I changed out the thermostat as it was stuck open. Appeared to have fixed the problem until last night but now the symptoms are different. Everything was normal until I looked at the scanner and coolant temperature dropped to 164 degrees while oil temperature was at 192. Lasted that way all the way to work. This morning, everything was normal, temperatures were 184/192 then the temperature dropped again to 164. About 30 miles later, temperature went back up to 180 for a few minutes than back down to 164. Oil temperature stayed at a normal figure for the entire drive. I thought it might be sticking open again but when it was stuck open in the past temperature was around 145. Tried searching but couldn't find anything. No apparent coolant loss and no loss of power. Any ideas?
Old Nov 9, 2025 | 01:12 PM
92blackandblue
4wd Low
Forgot to say, 2005 6.0.
Old Nov 10, 2025 | 06:43 AM
Baylinerchuck's Avatar
Baylinerchuck
Check your coolant level in the degas bottle. Where did you buy the thermostat? Have you done a coolant flush?
Old Nov 10, 2025 | 06:58 AM
92blackandblue
4wd Low
Coolant level is in the normal range, thermostat was bought at Advance Auto, and I last did a coolant flush 3 years ago.
Old Nov 10, 2025 | 07:00 AM
92blackandblue
4wd Low
Motorcraft brand thermostat.
Old Nov 11, 2025 | 08:37 AM
Baylinerchuck
These thermostats are pretty robust, but I guess anything can happen. I would look at the connector and make sure it’s dry not getting oil on it. Check the wiring and the loom it goes into. The sensor itself is not expensive so you could replace that.
Old Nov 11, 2025 | 03:59 PM
92blackandblue
4wd Low
Will give it a shot. Thanks.
bikerman2299
6.7L Power Stroke Diesel
Sep 15, 2025 11:50 AM
VG05
Mar 31, 2024 05:54 AM
Brian Hanks
Jan 6, 2020 09:41 AM
JonathanN
15
Dec 15, 2010 05:06 PM
Knox
Apr 17, 2010 07:58 PM
