whining sound?
Old Dec 8, 2003 | 03:45 PM
modru2004's Avatar
modru2004
whining sound?
when ever i give my truck any gas i hear a whining sound under the hood. its getting really annoying, it just started doing this. any idea about what it is, or whats causing it?
Old Dec 8, 2003 | 03:57 PM
mcanik's Avatar
mcanik
Power steering pump, Alternator. Two likely possibles.
Old Dec 8, 2003 | 05:48 PM
modru2004's Avatar
modru2004
well one of the whines was the powersteering, but there is another whine that happens during acceleration. its different from tehp ower steering whine that i corrected.
Old Dec 8, 2003 | 06:23 PM
95BlackF150's Avatar
95BlackF150
i once heard a torque convertor whine when reving engine sounded just like the powersteering pump was quite scary the person ended up having to put new Torque convertor on and rebuild the tranny but it was on a DODGE Neon lemon
Old Dec 8, 2003 | 06:56 PM
modru2004's Avatar
modru2004
my truck has a torque converter? how exactly could it cause a need for a transmition rebuild though.
Old Dec 8, 2003 | 07:12 PM
Tim Ervin's Avatar
Tim Ervin
The torque convertor bolts to the flexplate (similar to flywheel on a manual trans) on automatic transmissions and pumps the fluid. Pull your belt off and spin the air (smog) pump and alternator and idler (tensioner) pulleys. One might have a rough spot on the bearing which you possibly can feel. Another method is to spray WD40 behind the pulley (engine running) where the shaft goes into whatever. The bearing will be inside the housing but close to the front. Larger accessories like the alternator and air pump will also have bearings on the back side of the shaft. I had a '90 F250HD w/5.8L until recently and put 268K miles on it. My guess will be an idler/tensioner/air pump pulley and should cost $30-45. Air pump is not that easy to change but simple enough with a service manual. The other pulleys are straight forward. Check your belt, you may want to change it too if it is cracked. Whatever is squeling can lock up and burn/break the belt so don't wait too long. AC compressor can also squeel but most people don't have AC problems in Dec. and you could tell by turning AC off/stopping the squeel.
Old Dec 8, 2003 | 07:45 PM
modru2004's Avatar
modru2004
the whine is with climate control off, no heat or ac.
Old Dec 8, 2003 | 08:52 PM
homoudont's Avatar
homoudont
Tim Ervin
thanks fot the good overveiw of whats going on and what to do, i appriciate that when someone goes int o compleate detail and not just give hints. thanks man
