Side screen keeps defaulting to navigation Sync 4 Carplay
Old Nov 6, 2025 | 08:16 AM
dekeman's Avatar
dekeman
Is there a setting I haven't found that keeps the side screen where I left it?
While in Carplay, I keep changing the side screen to the music display, but it keeps reverting to navigation on startup.
Old Nov 6, 2025 | 08:53 AM
novalovr66's Avatar
novalovr66
Not sure about carplay specific but after you make the change are you saving it to the memory buttons on the door?
Old Nov 6, 2025 | 03:24 PM
dekeman's Avatar
dekeman
Door buttons don't save it.
Old Nov 7, 2025 | 06:39 AM
djernesd's Avatar
djernesd
Yes, I have wondered the same as well as, how to get rid of them so they don't automatically pop up.
Old Nov 7, 2025 | 12:10 PM
function12's Avatar
function12
Same problem on my '23.
Old Nov 11, 2025 | 07:43 PM
EverettWV's Avatar
EverettWV
8th Gear
I believe the trick to keep the side screen on music is to make sure the last screen you were before Android Auto / CarPlay on is the Nav one. Since if your phone does not connect instantly, it will go to the last screen you used. Since the music screen won't allow you to have music on the side as well, it goes to Nav. However if you start in Nav, the side screen will stay on music. Been about a week on my 26 where music stays on the side screen since I figured this out.
Old Nov 11, 2025 | 07:52 PM
dekeman's Avatar
dekeman
So, go to factory / Ford navigation, set side bar to music, then activate carplay, set sidebar to music and we're good?
Old Nov 11, 2025 | 07:56 PM
EverettWV's Avatar
EverettWV
8th Gear
Yep, set the side screen to music while on the factory nav, then go to carplay. I have android auto, but I imagine its the same thing. I guess I should test having music as my last screen and see if the problem comes back.
Old Nov 11, 2025 | 08:14 PM
dekeman's Avatar
dekeman
OMFG. Think you solved it! System stayed with music on side screen just now after setting it that way, will keep watch next few days. THANK YOU.
Old Nov 18, 2025 | 03:32 PM
function12's Avatar
function12
This worked for me. THANK YOU!!!!
Old Nov 19, 2025 | 11:05 AM
TestPilot57's Avatar
TestPilot57
Will have to try this. I have never found any discernable rhyme or reason for what shows up on the side bar.
Old Nov 19, 2025 | 11:55 AM
Poncho450's Avatar
Poncho450
I'd rather not have anything there. So I hit the little dual arrow button in the upper left corner and just go full screen with whatever I'm using.
Old Nov 19, 2025 | 12:22 PM
5picker's Avatar
5picker
Me too. If i want to see what music is playing, I look at my driver dash. It shows there and if that's not enough, I just hit the audio button and pull it up on the big screen.
Having the little panel up in the big screen Nav defeats the purpose of having the big screen!
Old Nov 21, 2025 | 05:06 PM
Tib's Avatar
Tib
This has been one of the annoying things I just dealt with. Thank you!
Scndsin
Feb 24, 2025 05:55 PM
Digger196
Nov 2, 2023 07:54 PM
Frank79
Jul 29, 2021 07:42 PM
PhilPalmiero
2021+ F150
May 16, 2021 08:57 AM
Super-Truck
Mar 17, 2017 05:53 PM
