High RPMs
Old Nov 4, 2025 | 09:37 PM
hayford's Avatar
hayford
4wd Low
High RPMs
I have an 89 F250 5.8 351. Today I changed the EGR valve and the coolant temp sensor because of codes I got off of a check engine light. Then once I turned on the truck it went into high rpms around 2000 at idle. While driving, I press on the clutch the RPMs shoot up to 3 or 4000 then drop. At idle it now sits around 1500-2000. I changed the IAC valve but it didn't change anything.
Old Nov 4, 2025 | 10:29 PM
My4Fordtrucks's Avatar
My4Fordtrucks
But you did change the EGR valve. Double check the vacuum lines in that area.
Old Nov 5, 2025 | 05:10 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Recheck for codes, again, codes dont always mean throw the parts cannon at issue, as bad as new parts quality is now-a-days, test first.
Fuel Injection Technical Library » Engine Coolant Temperature Sensor (ECT)
Fuel Injection Technical Library » EGR Valve Position sensor (EVP)
Fuel Injection Technical Library » Idle Air Bypass (IAB)
Boss_Hogg
18
Jan 21, 2019 06:56 AM
tdbronco77
Aug 13, 2012 05:58 PM
jordan101
Mar 14, 2011 08:21 AM
Surf Fishn Truck
1978 - 1996 Big Bronco
Oct 25, 2008 08:03 AM
jopey
Oct 11, 2000 01:50 PM
