Fuel tank sender
Old Nov 3, 2025 | 05:25 PM
lalberts's Avatar
lalberts
Fuel tank sender
Is there and easier way to adjust the fuel sender so it is accurate without having to drop the tank every time to get the sender out to adjust it?
Any ideas would be greatly appreciated!
Old Nov 3, 2025 | 07:24 PM
motorsickle1130's Avatar
motorsickle1130
Look up resistance specs for your gauge and sender, and try checking across the leads of the sender with a multimeter set to ohms/resistance.
Not sure if there’s much more to be done besides adding an inline resistor as needed to compensate if the sender is low.
If the range is way off perhaps you need a different sender or a different gauge.
sbraatz
Mar 7, 2023 10:56 AM
Nwtravler
26
May 4, 2022 07:27 AM
dakotajeep
Mar 12, 2008 09:35 PM
dbull65
Feb 4, 2005 06:27 PM
