Solid axle '94 f150
Old Dec 8, 2003 | 02:37 PM
fourplay ford's Avatar
fourplay ford
Solid axle '94 f150
Will the tech article for putting a '78 solid axle in a '95 tell me what I need for my '94? In the article the guy uses the the coils and radius arms from the '78. What are the pros and cons of using this setup vs. a leaf spring setup?
Old Dec 12, 2003 | 03:43 PM
threefords's Avatar
threefords
I have leafs and a Dana 44 on my 86 F-150. Lots of welding to mount shackles and reinforce frame. Crossover steering eliminates bumpsteer. lower shock mounts were fabricated. I think leafs are stiffer than coils. Watch out for front driveshaft angles and rubbing on crossmember. Also watch clearance on engine crossmember. Good luck! I'm very happy with my final product.
Old Dec 12, 2003 | 06:58 PM
78f3504x4's Avatar
78f3504x4
My buddy and I put a 78 Bronco 44 in my 94 2 years ago. Came out awesome, was almost a bolt-on. Minimal fabrication, and almost all the parts needed are available at the parts store or the boneyard. Leafs will ride stiffer, and the coils (I used Skyjacker 4" coils for a 78/79) are easier to adapt. They will fit right into the 94 upper coil buckets. Any more questions post 'em. I have swap pics in my gallery. Good luck! Steve
swampbusiness94
17
Apr 10, 2011 10:06 PM
ptboi94
Feb 23, 2011 10:40 AM
Rediranch_too
1978 - 1996 Big Bronco
Jan 25, 2011 12:27 AM
rkshipley
Nov 29, 2004 06:52 PM
BroncoRoadKill
Apr 22, 2003 11:57 PM
