speedometer bouncing
Old Nov 3, 2025 | 08:15 AM
that94xlt's Avatar
that94xlt
Trailering
its fairly accurate (slightly bouncing) up to about 30-35 then after that it just starts going haywire. I bought a new vss (the one on the diff) Saturday and replaced it. I went from no speedometer and odometer not going up to a bouncy speedometer and a odometer reading. any help would be appreciated.
1994 Ford F150 XLT w/ 5.0 & E4OD 2wd
Old Nov 3, 2025 | 02:42 PM
knottyrope's Avatar
knottyrope
Check VSS wiring to the dash and ohm it out too.
Change gear oil in diff? metal bits can fool it.
PSOM can go making you think its VSS related
Old Nov 3, 2025 | 04:22 PM
that94xlt's Avatar
that94xlt
Trailering
I ohmd the sensor before it went in and I was getting 1800-2000 ohms (apparently what is supposed to be around) but I also read that if it’s “too close or too far” from the tone ring it could cause issues yet the old one was in all the way? Not much of a electrical person so I’d have no clue how that’d affect it but when I get a chance I’m probably going to see what I can do about inspecting the tone ring from the vss hole (since that seems to be a common issue) and probably have a shop change it plus the oil if it’s a issue since I have no experience with differentials
Old Nov 4, 2025 | 10:15 PM
seschenburg's Avatar
seschenburg
I heard somewhere and in another time that there is a capacitor on the PSOM that can leak and play havoc with the speedometer. Swapping the PSOM might be the easiest way get a look at that capacitor and to see if that's the problem.
fancyvern
2009 - 2014 F150
Jan 27, 2025 06:14 AM
Mich6.0
Escape & Escape Hybrid
Nov 28, 2023 09:55 AM
rvpuller
May 29, 2019 10:16 AM
Punisher29073
Jun 12, 2013 12:39 PM
