Snow tire size
Old Nov 2, 2025 | 04:35 PM
66Classic96's Avatar
66Classic96
Snow tire size
Looking to get suggestions for a set of winter tires for my 1966 F 100 Custom Cab long bed.
Currently, the previous owner has 235/70-15 on the front (The 235/70R15 tire has a diameter of approximately 28 inches (711 mm), a tread width of about 9.3 inches (235 mm), and is designed to fit a 15-inch wheel rim. The sidewall height is roughly 6.5 inches (165 mm)
and 255/70-15 on the rear. (The 255/70R15 tire has a diameter of 29.1 inches, a width of 10 inches, and is designed to fit a 15-inch rim. It typically has a sidewall height of about 7 inches )
Truck has been lowered slightly by previous owner, guessing maybe 2-3 inches.
I notice the speedometer shows 2-3 mph slower than actual road speed.
I believe I have a 3.54 rear end gear, if i decoded VIN tag correctly. 3 speed 3.03 transmission.
I have read other posts on stock tire size that suggest to be around 6.70-15 to 7.75-15.
Do I stay with 70 series or move to 75 series. Would 215's or 225's be a good option?
I have looked at so many different tire specs recently, just looking for some guidance on which direction to go. Thanks.
Old Nov 3, 2025 | 01:17 AM
66F250_4x4's Avatar
66F250_4x4
First thing I'd do is decided what diameter you want on the rears for gearing. If you like the gearing now, i'd stay within 5% of the current diameter. Any more and I think you'll really feel the change. Otherwise, if you want it to pull easier or be snappier off the line, go a little smaller. Or a little taller for lower highway rpms.
I bumped up my other truck tires a little more than 5%, and it feels like a dog to me. Wish I hadn't. But my son drives it now and he doesn't know the difference.
Old Nov 3, 2025 | 04:43 AM
'65Ford's Avatar
'65Ford
I believe a taller and narrower tire is better at clearing water and slush than a shorter and wider tire. Wider tires tend to "float" on water and slush. I like 235/75/15 on a half ton and wouldn't go any shorter or wider for a pickup in the F100 weight range.
Old Nov 3, 2025 | 04:55 AM
charlie g's Avatar
charlie g
FTE Community Team
with 65ford, narrow do better in snow and slush,
bucks-heritage
Jan 24, 2005 11:35 PM
UNLOADIT
2004 - 2008 F150
Nov 17, 2004 01:25 PM
schapman
Nov 19, 2003 12:27 AM
vtsocalm
Jan 11, 2002 07:10 PM
canadianfordman
Dec 3, 2001 04:23 PM
