Cranking issue
Old Oct 31, 2025 | 05:48 PM
BadgerWI's Avatar
BadgerWI
7th Gear
Cranking issue
Have a 79 4 speed with a 390 that I put in a few years ago. I have had difficulty starting the truck after I go through the typical pump once to open the choke and give it an additional 4 - 5 pumps on the accelerator before cranking, slightly holding down the pedal as I crank. I've found that if I ever so slightly turn the key from "on" to "crank" just enough to allow the starter to engage, then let off the key quick so that it immediately turns to the on position, it fires up. In the past I had to crank for several seconds, wait and try again, and again, wearing on the starter and battery.
I put a meter on the ignition module and see that it puts out only 6 volts when running. Have not checked with the meter when cranking as I was doing this solo today. Would my ignition module be failing? Can I run a jumper from my battery terminal to the coil to put 12 volts to the coil be a test to determine if the module is no good? Just looking for some feedback.
Old Oct 31, 2025 | 06:11 PM
JimsRebel's Avatar
JimsRebel
I put a meter on the ignition module (module or coil???) and see that it puts out only 6 volts when running. Have not checked with the meter when cranking as I was doing this solo today. Would my ignition module be failing? Can I run a jumper from my battery terminal to the coil to put 12 volts to the coil be a test to determine if the module is no good? Just looking for some feedback.
6 volts at the ignition coil positive while running is normal.
While it tends to start as soon as you remove current flow to the starter ... does sound like a weak battery... As the voltage will jump up as soon as you remove the heavy draw from the starter motor. Or it could be the starter motor is drawing to much current, dragging the voltage down.
I would run a jumper wire to the coil positive, directly from the battery positive, for testing.
The "I" output of the starter solenoid is supposed to provide full power to the coil positive while cranking, this wire bypasses the resistor wire.
Don't rush out and buy a new DS2 ignition module, this seem extremely unlikely... As it runs fine after it starts.
Jim
Old Oct 31, 2025 | 07:25 PM
kenny nunez's Avatar
kenny nunez
Hard start
Look at the fender well solenoid, the small terminal marked “I” should provide 12 volts in cranking mode. This circuit provides current to the coil to help starting.
Old Oct 31, 2025 | 09:58 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
This usually means the ignition switch is getting bad.
rumblefish73
24
Sep 15, 2024 10:54 AM
Diymechanicmike
Large Truck
19
Sep 6, 2024 03:43 AM
DocAdam
May 17, 2020 03:14 PM
Thunderbird7480
Feb 9, 2020 02:51 PM
Echotop
Mar 20, 2017 09:04 AM
