"dropping" the interior fuse box - how?
Old Oct 31, 2025 | 03:35 PM
RolllingM's Avatar
RolllingM
Trailering
Hi all. I'm finally back to the Ford Super Duty family. 2026 F250, Lariat, crew cab.
My first question, and apologies up front if this is already covered in these forums. I searched every term I could think of, but did not find anything.
I was able to remove the "soft cover" to get to the cab fuse box. And removed the box cover. But I simply cannot figure out how to get the fuse box to "drop" down, so I can work on it.
I unclipped the grey tab on the driver's side of the fuse box, and the box dropped a little bit. But no more.
Is there something else I need to release?
Many thanks.
Old Nov 1, 2025 | 02:44 PM
RolllingM's Avatar
RolllingM
Trailering
My bad. I thought the fuse box would simply drop down. Not so.
I crawled up under the box and looked for screws holding the box in place, but didn’t see any.
Any suggestions for where to find such screws?
Thanks
Old Nov 1, 2025 | 03:13 PM
dadsf100custom's Avatar
dadsf100custom
Old Nov 1, 2025 | 03:31 PM
RolllingM's Avatar
RolllingM
Trailering
Good videos, thank you. I'm going to keep searching, and try to find out how to get the box to drop down.
thanks,
chris
Originally Posted by dadsf100custom
Try this:
And this:
Old Dec 22, 2025 | 05:02 PM
RolllingM's Avatar
RolllingM
Trailering
SOLVED
Most folks may already know this, but since I had been stuck, and have now figured it out, I thought I'd post up.
First, you have to remove the fabric cover, so you can get to the fuse box area. I'm not showing that, it's just 3 plastic fittings, along the front.
Then, remove the glove box; drop the box by releasing the tabs on each side of the box, and then lift the box off.
To drop the fuse box, you can remove the box cover, or leave it in place, doesn't matter.
There are two clips which hold the box in place. One is on the side, toward the driver. The other is on the side toward the passenger. I've included pictures below. I also have a short, not-professional video, showing the release of the clip toward the driver. Release both clips, and then kind of wiggle the box down, and free. To fully remove the box, pull up on the big clamp.
Hope this helps.
-chris
The clip toward the driver.
The clip toward the passenger.
Drop the box down.
Drop the box down.
Release the big clamp.
File Type: mp4
remmers
1997 - 2003 F150
Oct 23, 2024 09:48 PM
BCM
Mar 31, 2022 05:09 PM
2007FEH
Escape & Escape Hybrid
Sep 12, 2018 05:14 PM
300/6 Freak
Apr 2, 2010 12:14 AM
