More Power
Old Oct 29, 2025 | 07:17 AM
90project5.0's Avatar
90project5.0
Depending on your mechanic skills, but you can get a spare head from a junkyard. Take your time, watch videos and read forums. Port the head to help it flow better. When you install, put higher ratio rocker arms, you’ll notice the difference. If you do the work yourself, the price/hp gain is worth it.
Old Oct 29, 2025 | 08:21 AM
Hit Man X's Avatar
Hit Man X
Yep, port the head. 1.72:1 Scorpions. 3.55:1 gears. Regrind your cam for a bit more ***, cam cores are very hard to find for the L6. High flow muffler of some sort.
That is about it that will pass smog and still allow use of the stock fuel injectors.
Old Oct 29, 2025 | 09:23 PM
TobyB's Avatar
TobyB
until they insist on the visual
Seriously, you're gonna need a different truck if you want more power, better gas mileage and CARB.
Unless you Tesla swap it. That might work.
t
Vinford
2021+ F150
Jun 12, 2025 11:05 AM
mikeo0o0o0
May 16, 2017 08:19 AM
JLaw92
Nov 12, 2011 01:12 PM
whittey
Mar 25, 2002 10:28 PM
