Eco mode?
Old Oct 28, 2025 | 10:24 AM
DPelletier's Avatar
DPelletier
Never used it and never will though I did try it once. IMO, you could duplicate the effect on mileage by driving like a "hypermiler" ......I, on the other hand, prefer how my truck drives in tow haul even when empty.
Dave
Old Oct 28, 2025 | 10:40 AM
GAZZILLA's Avatar
GAZZILLA
What does “ECO” mode do anyway?
Short shift the transmission and retard throttle input?
That’s what “SLIPPERY” mode seems to do.
Old Oct 28, 2025 | 09:44 PM
MLBajorek's Avatar
MLBajorek
Originally Posted by 99powerstrokedF250
[snip]
Sport mode, though, yes, does decrease mileage...because in everything I've driven that had it, it's a LOT peppier, holds the gears longer, and on the Expedition and Bronco it engages the auto4X4 for better traction...it's quite a bit of fun.
I never bothered to check; does the 2026 F250 even have a sport mode?
Old Oct 28, 2025 | 10:05 PM
Pickupmanx2's Avatar
Pickupmanx2
I used the Eco mode once on my '22 F550, once, what a joke, it's already neutered as a CC so it was even worse, when I get in and start it, I hit it 5x and put it in the deep sand/snow mode, turn on the EB, turns off TC and makes it way better to drive, TH is close, but the sand/snow mode works best IMHO for it, then I shift it manually when needed.
Old Oct 29, 2025 | 08:30 AM
Kidder69's Avatar
Kidder69
That's exactly what ECO mode does. I assume slippery mode puts it into 4H? The only modes I've used are normal, eco, tow/haul. I use eco on long trips when I'm not towing. I don't like it in town.
Old Oct 29, 2025 | 09:12 AM
scraprat's Avatar
scraprat
Top Answer: 5
Tap advance trac off 2x ... Sports mode...No eco baby .... 😆
Old Oct 29, 2025 | 09:48 AM
seijirou's Avatar
seijirou
The 23+ don't do that anymore I believe.
Old Oct 29, 2025 | 09:55 AM
seijirou's Avatar
seijirou
I'm pretty sure that's correct, as well as reducing rate of acceleration when cruise control is on.
It's like the throttle modifiers (pedal commander, pedalmonster..) but in the other direction. Where those exaggerate throttle inputs, this retards throttle input. Neither are doing anything you can't already do with your right foot.
$100 says its not changing any engine running parameters that could increase fuel efficiency like valve, injection, or ignition timing because there's no reason Ford would leave that mileage on the table in normal mode (EPA requires using normal mode), reducing advertised efficiency.
Old Oct 29, 2025 | 09:01 PM
GAZZILLA's Avatar
GAZZILLA
On my 2022 “SLIPPERY” mode does not put it into 4H, “DEEP SNOW/SAND” mode does.
Old Oct 30, 2025 | 02:02 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I don’t need my truck trying to drive like it thinks it needs to. I leave mine in normal…I’ve never used any of the other modes and never will.
Old Oct 30, 2025 | 10:52 PM
dadsf100custom's Avatar
dadsf100custom
I bought the 7.3 for its potential power and instead of showing a green leaf they should of put a set ***** with a line through them. "
LOL
Quote of the YEAR!
Ford should allow more customization, which would foster more sales.....
Old Oct 31, 2025 | 09:47 AM
roadpilot's Avatar
roadpilot
I'm less than 800 miles in on my '26, so (a) I know it's still breaking in and (b) I know the Lie-o-Meter for MPGs is nowhere near as accurate as hand-calculations (I'm only on my 2nd tank, so I can' even begin to do that), but I drive ~50 miles one way to work three days per week, 95% of it on the freeway. Fridays are always wide open. I hit the freeway, reset the Fuel Economy meter, and let the 6.7L PowerStroke F350 Platinum lumber all the way to work @ 70 MPH in ECO mode (all flat here in Michigan): 22.9 MPG this AM. Using Archoil 6500, BTW. After I get a few thousand miles on it and have the ability to hand-calc my MPGs, I'm hoping for good numbers.
Old Oct 31, 2025 | 10:45 AM
  #28
GAZZILLA's Avatar
GAZZILLA
I don’t use ECO mode because I don’t like the deadened throttle response or the short shifting. I increase throttle response with a Solar throttle controller.
Old Oct 31, 2025 | 12:38 PM
  #29
roadpilot's Avatar
roadpilot
Agreed. But like @Kidder69 said, " I use eco on long trips when I'm not towing."
Old Nov 2, 2025 | 07:55 AM
  #30
roadpilot's Avatar
roadpilot
No matter what "mode" you put it in, you should be able to (then) put it into 2H or 4H by using the 2H or 4H button after putting it into a mode.
I used to put my F150 into 'Sport' mode (which automatically put it in 4H), then I hit the 2H button. That put it back in 2H but left it in 'Sport' mode.
I assume the '26 SD will do that, just haven't tried it yet (only have like 900 miles on it).
IIRC, 'Slippery' mode in my F150 did put it in 4H by default.
