Fuel pump ground location?
Old Oct 25, 2025 | 10:54 PM
Bueller's Avatar
Bueller
‘89 F-350….anyone know off the top of their head where the fuel pump ground (coming off of the module) terminates?
Frank
Old Oct 25, 2025 | 11:12 PM
Soup bean's Avatar
Soup bean
The fuel pump circuit ground is near the windshield washer bottle, either on the inner fender or the radiator support.
Old Oct 26, 2025 | 08:49 AM
Bueller's Avatar
Bueller
Copy that! Bought a Dakota digital instrument panel, and they’re specific about inputing the fuel pump ground to their hardware…thanks! 👍🏻
Frank
Old Oct 26, 2025 | 01:19 PM
Soup bean's Avatar
Soup bean
Frank
That ground location is common to the headlight circuit also. I don't know if that will matter to your aftermarket gauges.
Old Oct 26, 2025 | 02:01 PM
Bueller's Avatar
Bueller
It may not matter at all..it seems like that portion of the instructions is more generalized, since they say it’s recommended for accuracy, and talks about a grounding wire off of the pump sender plate…those of us that know, know there’s no fuel sender attachment bolts 🤷🏻‍♂️
May end up rolling the dice, and snagging one of the grounds going to the cluster. Guess if there’s issues, I can always do it their way.
Frank
Old Oct 27, 2025 | 12:13 PM
Scndsin's Avatar
Scndsin
There's generally a main harness ground in the driver's kick panel.
What I use for anything in the cab or dash.
Old Oct 27, 2025 | 02:30 PM
Bueller's Avatar
Bueller
That’s good to know, sir..I’ve got some more grounds to hook up! 👍🏻
Frank
suburbanE450
1997 - 2003 F150
Jan 8, 2024 08:19 AM
Spentkarma9
2004 - 2008 F150
Dec 14, 2023 02:50 PM
cactusjack24
2004 - 2008 F150
17
Jan 14, 2023 10:26 AM
