Booster/check valve
Old Oct 25, 2025 | 02:03 PM
CliffFord71's Avatar
CliffFord71
Trailering
Booster/check valve
Hey guys question, i have a hissing noise under the dash and a squealing noise .im pretty sure it’s booster so I ordered one that will be in Monday. Could it also just be a check valve alone or did I do the right thing by just getting a whole new booster? I also think diaphragm in booster could be damaged. I tried to check the Clevis to see if there was a way to check adjustment, but when I brake it also idles fast. Thoughts?
Old Oct 25, 2025 | 06:01 PM
KULTULZ's Avatar
KULTULZ
Arrow
If the noise is inside the cab (hissing on brake application) and the engine speeds up while braking (indicates vacuum leak), the booster diaphragm is most likely bad.
GJCAT
Oct 23, 2020 07:37 PM
azfordf100man
Oct 16, 2007 12:12 PM
davidc-austin
Jan 10, 2005 11:13 PM
Senscient Tortoise
Sep 13, 2004 12:40 AM
