Click no crank
C13 CHECK THE RUN/START RELAY CONTROL CIRCUIT SUPPLY
- Measure the voltage between the run/start relay socket pin 1, circuit SBB45 (GY/RD), harness side and ground.
Is the voltage greater than 10 volts?
Yes GO to C14.
No VERIFY the BJB fuse 45 (10A) is OK. If OK, REPAIR circuit SBB45 (GY/RD). If not OK, REFER to the Wiring Diagrams manual to identify the short to ground in circuit SBB45 (GY/RD). CLEAR the DTCs. REPEAT the self-test. TEST the system for normal operation.
C14 CHECK THE RUN/START RELAY CONTROL CIRCUIT GROUND FOR AN OPEN
- Disconnect: BCM C2280F.
- Measure the resistance between run/start relay socket pin 2, circuit CDC55 (BN/VT), harness side and BCM C2280F Pin 18, CDC55 (BN/VT), harness side.
Is the resistance less than 5 ohms?
Yes GO to C15.
No REPAIR circuit CDC55 (BN/VT). CLEAR the DTCs. REPEAT the self-test. TEST the system for normal operation.
C15 CHECK THE RUN/START RELAY CONTROL CIRCUIT FOR A SHORT TO GROUND
- Measure the resistance between run/start relay socket pin 2, circuit CDC55 (BN/VT), harness side and ground.
Is the resistance greater than 10,000 ohms?
Yes GO to C16.
Yes RECONNECT the electrical connectors and relay. CLEAR the DTCs. REPEAT the self-test. If DTC B1310:14 is still present,
C16 CHECK THE RUN/START RELAY
- Carry out the appropriate relay component test.
Refer to Wiring Diagrams Cell 149 for component testing.
Is the run/start relay OK?
No INSTALL a new relay. CLEAR the DTCs. REPEAT the self-test. TEST the system for normal operation.
I have one of these to check batteries. It gives a complete check, including the instantaneous voltage during starting.
